EA82 Dying in gear
Matt
EA82 Dying in gear
Post by Matt » Fri Aug 14, 2015 6:18 pm
I have a L series with a EA82 Auto in it (Not my car) that dies when you have it in drive and stop a reasonable rate. If you stop super slow it doesn't die but comes close. Is it ment to have an idle kick up solined or something?
"Claudia"
Matt
Post by Matt » Mon Aug 17, 2015 7:25 pm
Bump
"Claudia"
Post by steptoe » Tue Aug 18, 2015 8:41 am
not had an idle kick up solenoid in either of my auto's,- as far as a carb or throtttle is concerned but one was MY, another was turbo. I think all this you have would be in the box itself, which may be asking for a service and maybe some fluid enhancer - Nulons G60 comes to mind- could be a hard to get at o ring causing some sluggishness
Post by El_Freddo » Fri Aug 28, 2015 8:50 pm
Could be a vacuum leak on the engine or low compression.
Is it carb or MPFI? How many k's and how does the engine run in general? Does it still shift gears properly?
