Subi snow shots
legacytt
Subi snow shots
Post by legacytt » Mon Aug 03, 2015 2:37 pm
We are in the middle of a big snow dump in Tassie at the moment so I went out for a drive today. As my lifted Liberty is out of action due to a dead clutch I had the standard Diesel Forester. With Chains fitted it did a great job, even with snow deep enough that it was almost snow ploughing.
I think one of these with a proper body lift and low range box would be quite capable. Has anyone heard of issues with the traction control playing up when a lift is fitted? By that I mean cross member spacers as well as strut lift. While the dual range would lose the nice tall gearing of the 6 speed the current first gear is no good for steep hills etc.
Post by steptoe » Mon Aug 03, 2015 3:23 pm
Some nice shots. Bet you can't wait for the big thaw !!
Post by El_Freddo » Mon Aug 03, 2015 10:29 pm
Nice mate, I'm pretty jealous!
I love driving my subi in the snow, so I lapped that up while we lived in the alps. I still pine for it!
vincentvega
Post by vincentvega » Tue Aug 04, 2015 10:30 am
i dont know how well a dual range would hold up behind that much torque. you would have to be very careful with the right foot..
awesome pics mate
legacytt
Diesel Dual Range
Post by legacytt » Tue Aug 04, 2015 5:38 pm
I suppose the Torque is up there with the Turbo engines. I have only stripped 2nd on a dual range box behind a turbo engine when towing too heavy a load, otherwise they have held up well with sensible driving. Waiting for someone to retro fit a diesel engine into an early Lib, now that would be an interesting combo.
KiwiL
Post by KiwiL » Tue Aug 04, 2015 6:53 pm
The EE20 has some 350 Nm of torque at 1800-2400rpm, whereas the EZ30D has only 289 Nm at 400rpm. So that's a LOT more torque than anyone has probably ever put through a D/R before and at lower RPMs too. It would be interesting to see how it held up.
Some early diesel Outbacks here in NZ did use the 5-speed S/R though so if that held up a later D/R with the wider 1st and 2nd gears could be ok. Don't know how well the 1.59 gearset out of an L would do though...
legacytt
Diesel Dual Range
Post by legacytt » Tue Aug 04, 2015 7:32 pm
Fair points there, it definately likes to pull from 2K revs onwards. Probably better with an auto that has a setup to lock the centre diff.
vincentvega
Post by vincentvega » Tue Aug 04, 2015 8:13 pm
i have read a few guys say 400Nm is possible with just a tune. Thats HUGE in such a small car.
350Nm is a long was from the 180ish Nm an EJ22 dual range was intended to handle.
