Gearbox Leak
Gearbox Leak
Having fixed the Oil pump leak issue now turn my attention to a transmission fluid leak in the Brumby. Appears to be on close inspection coming from the seal on Shifter arm sticking out of the extension housing. Looking at the Workshop manual I have it gives no dialogue on what is involved in replacing the oil seal on the shifter arm. Has anyone had to tackle this job. Majordad
- Bantum
Oil Seal ...
Umm... I'm assuming your talking about this seal :
I think it requires pulling the box out & a strip down to get to it ... ?
I could be wrong, but El_Freddo knows more about them ...
Cheers, Bantum ...
Cheers, Bantum ...
Gearbox leak
That appears to be the one Bantum except mine has the end of a split pin sticking out of it. majordad
Remove the shifter mechanism, do the bolt and slot trick while it's off. Once you've got that off clean up any burrs on the selector shaft, remove the old seal and replace with a lubricated new seal.
I think I used a deep socket to tap it back in place if I remember correctly. Pretty easy over all.
Another note, it's a good idea to thoroughly clean the area you're working on. Makes things very easy.
Used to do mine on an annual basis due to some impatient dude who welded the shifter to the rail to rid the slop
The weld extended into bashing the seal every 2nd and 4th gear shift. I think I just dropped box by the crossmember to work in there
it is NOK ARO 677G
gen # 80671 6020
technical 16,26,7 mm
it is NOK ARO 677G
gen # 80671 6020
Gearbox Oil Leak
Thanks for the input fellas, thank christ the gearbox doesn't need to come out.
Majordad
Majordad
