RAM performance have these flanges for sale. $169 pair think NZ dollars.
see http://ramengines.com/page16.php
I was wondering. All the guys here and elsewhere that want twin carb manifolds that are impossible to get, why cant they use these flanges?
I assume a steel tube would fit into the hole then a carbie base plate then bolt the carb on each side. bolt in a barb each flange for the hose and connect. The PCV is a worry. How much more hp would it roughly increase by using two single throat carbs?
Discuss away. Tony
