Remove & Replace sump Gasket.
I have to remive the sump on mt Brumby to replace the gasket. Bolts on front and sides seem a piece of cake, but the back bolts look like a night mare to remove and replace. Any ideas out there.
I haven't done the sump gasket on my Subaru yet but I have done it on a Daihatsu CB23 and a Nissan L20B without removing the subframe. The Subaru looks a bit easier. I would use a ring spanner, 1/4" drive socket, ratchet, a few different extensions (with wobble joints if you have them) and a lot of patience.
I have to do mine before easter in the MY, leaking about 100mm of oil a day out of the gasket...
the little plate on the bottom of the crossmember where the sump guardd bolts onto, this has to be removed. Drill out the 4 spot welds, replace with nut and bolts. With the plate removed you can get to the rear bolts. There are holes in the crossmember to get a 10mm deep socket through for the back bolts.
where have you sourced the gaskets from?
Can we please start using the sub forum topic pages for these threads?
If you've not subscribed I'd recommend you do to allow access to post new threads in these sections of the forum.
Personally I'd pull the engine and do the rear main and other little bits of maintenance while everything is easily accessible.
Taza, I'll be checking these little holes out to see what you're talking about
I think it can help by undoing engine mounts at xmem end and lifting engine a bit to get better access but, you want th gasket to come off cleanly on the sump itself, not bust up and leeve bits on the block, bits on the sump pan and the old cork is hard as and stuck like baby poo to a blanket
. Some good scraping chisels wil be on your list. Or like above, pull engine and do some seals as well, new OP switch also helps with leaks
