Brumby/MY lift kit bolts
Post by Silverbullet » Sun Aug 31, 2014 2:28 pm
A while ago I thought I remembered someone asking what bolts are required when lifting a Brumby/MY wagon. Stuffed if I can find the thread now but I've just gone through the lift blocks that I have for my wagon, measuring up the bolt lengths, diameters and pitch.
So these all seem to be metric fine threads, or 1.25mm pitch. All should be ordered high tensile. The bolts required for the front strut tops and rear shock mounts are not included below, since the strut tops don't use longer bolts and rear shocks depend on what kind of lifting bracket you use, usually not requiring longer bolts.
The following list is for a 2 inch lift kit
Engine crossmember bolts:
M10x1.25 - 4 x 150mm long
Radius rod mounting plates:
M12x1.25 - 6 x 75mm long
Rear torsion bar tube:
M12x1.25 - 4 x 100mm long
Rear moustache bar mounting brackets:
M10x1.25 - 4 x 75mm long
I think that's all there is, 18 bolts total. If I've forgotten anything I'll add to the list when I come to installing my lift kit, coming soon.
Caddy
Post by Caddy » Sun Dec 07, 2014 12:49 pm
Where did you source your lift kit from, and did it not come with the bolts
Post by Silverbullet » Sun Dec 07, 2014 9:44 pm
My kit is made up from bits and pieces I've found at wreckers and made myself. And the bolts that were holding them on the wrecked cars were not even fit to hold a gate up :neutral: So I ordered all new ones from a specialty fasteners place. Luckily for me I know someone who can order through their work etc etc so got them at a very good price.
henpecked
Post by henpecked » Tue Dec 09, 2014 10:06 am
Hi
may want to specify/confirm that this was for a 2" kit block all round -( at least that's what I remember your intention was when measuring off from mine)
- edit your first post and I'll delete this one
cheers
Post by RSR 555 » Fri May 01, 2015 11:05 pm
Nice work and this should make a nice quick reference for future lift kits :cool:
