L rear k frame into brumby
$tando
Post by $tando » Wed Aug 20, 2014 8:21 pm
Can it be done
After reading 30 pages about found nothing
This has started
I have a 1990 brumby with ea82t and 5 speed
I'm needing the freedom of an l series rear k frame and set up
I'm running the air shocks at the moment from an rx sedan with the brumby torsion and it's not bad but I have no flex or movement inderpendantly
My question is
Do the bolt holes line up or is the l series wider ??
Also will honda civic coilover sockets match the brumby hubs ??
$tando
Post by $tando » Wed Aug 20, 2014 8:59 pm
Crisis averted
The L series frame won't fit
So all I can do is lower the resistance of the torsions and run L series shockers and springs
The front cool over idea is still being chased
I believe mark2 VW golf or 95 honda civic also run a coil over with a 44/46mm diameter inhub coilover
I'm still researching this but if so
They should fit and all that need to be fitted is correct top plates and positioning
Post by El_Freddo » Sat Aug 30, 2014 12:55 am
Ask Toonga about running the L springs in the rear of the brumby, I'm sure he's done it and didn't like it.
But you might find something that works...
