subaru Lseries pleas help
hi guyz can sum one pleas help me work out
whats rong with my subaru Lseries.
ok when i drive it the steering wheel shakes relly bad
its been geting worse over time. what could this be.
and all so iv got a new daily driver so im planing on
letting the subie run out of reg as cant afford
to keep both cars reg. but wanted to do the subie up
for off road use. is there a way of making my own
lift kit. and were is a good place to find 14inch wheels
as iv looked every were. thanks guys
- Silverbullet
You probably won't find any new 14" wheels in the right stud pattern, try wreckers yards and places like U-pull it (or the Victorian equivalent) I lucked out one day and found an old lifted MY bush basher with 4 14" wheels still on it, went back to the same yard a couple weeks later and found an L series with 2 more. Sometimes you can be lucky.
I will be moving on my Pug 504 wheels in a few months, but if you're looking for something sooner go to pugwreck in Bayswater. Budget on $40-45 a rim, plus rubber.
well have to look them up. dont need them in a rush
wana fit sum mud tyres on them sum one told me
you cant get mud tyres for the 13inch stock wheels
is this tru. im planing on using my Lseries for a off road
camping car as il tow it so i dont have to worry
about it being road worthy. so i dont cear what i put
under it as long as it fits lol. all so wana try and make
sum kind of lift kit for it.
You'll find that your vehicle needs to be registered to use it offroad in Vic - it's still deemed public road in the State parks/State Forests/National Parks etc. Unless it's private land you need registration and the driver needs to be licencedBen james wrote:iv got a new daily driver so im planing on
for off road use.
Stock 13 inch rims you can still get the stock size rubber in a Toyo iWinter tread - it's a mud + snow tyre, very soft rubber. I recommend NOT running them in summer otherwise you will literally watch the tyres wear down between drives!Ben james wrote:you cant get mud tyres for the 13inch stock wheels
is this tru.
As for larger rubber on a larger rim, 27s on a 14 inch rim are still available and will fit with a two or a three inch lift with minor guard cutting to the front guards.
