brumby vs l series
FALCONCONVERTTOSUBARU
brumby vs l series
Post by FALCONCONVERTTOSUBARU » Sun Jul 27, 2014 2:30 pm
do brumbys have more ground clearance than L series if so would it be possible to fit brumby springs to an L series wagon.
coxy
Post by coxy » Sun Jul 27, 2014 4:55 pm
In a word no, Adjustable spring platforms on the front struts and Torsion bars at thye back that can be adjusted up or down.
But one mod for brumbies is to retrofit L series rear struts that then adds coil over struts to a Brumby but not the other way.
Plenty of lift kits ans spring changes though for L series vehicles a search in the Tech section or a look at others Cars in the members section will steer you the right way
Post by FALCONCONVERTTOSUBARU » Sun Jul 27, 2014 7:03 pm
ahh ok just gumtree reckons brumbys have 215mm ground clearance vs 190mm of the L series but that must be with suspension raised up on the brumby.
Post by El_Freddo » Sun Aug 03, 2014 7:22 pm
FALCONCONVERTTOSUBARU wrote:ahh ok just gumtree reckons brumbys have 215mm ground clearance vs 190mm of the L series but that must be with suspension raised up on the brumby.
This also depends on an L 4wd wagon or an L 2wd sedan - both have different heights...
Post by FALCONCONVERTTOSUBARU » Wed Aug 27, 2014 8:55 pm
ahh ok.
