I did an EJ22 rebuild. Nasty business
- PeterVWsuby
I have an EJ22 in a 1975 VW Bus. I put a 2H engine in back in about 2004. It lasted 4 years. I put another 2H engine in in 2008. It lasted 5 years. So I decided to rebuild this time. I had two Subaru remanufactured fully rebuilt heads . Genuine new Subaru valves etc. that I got off ebay for $200. They were Subaru sealed. So I got a full rebuild kit with every bearing, seal, timing belt kit, waterpump, oil pump, pistons etc. through a family member. All big name brand parts, including ARP head stud kit and lots of Japan made seals etc. $800 for the lot. After spending $1800 on machining to 0.0001 thou (tenth of a thou), full balancing, weighting of rods, flywheel, clutch etc. I had all the best I could without being race prepared. So after spending about $3000, I assembled the engine. Followed everything correctly. It started instantly. I was very happy. Then I noticed water leaking from the back of the engine behind the flywheel. I was sad.
I got up the next day, pulled the engine, and found a small crack in the back of the block. I had hydrauliced one of the ARP head studs. So after locating another block and getting $600 machining done. One thread in the front of the block for a timing pulley was stripped. I helicoiled it, but the tap in the kit was different to the bolt, I got a new bolt. I was ready to start it again. Fuel line split, got a fuel line, It would not start, fuel in and return were on wrong, would not start. After sleepless nights trying everything, I eventually found I had the timing belt on wrong.
Any way to cut a veeeeery long story short, as I have left a lot out. It now runs sweet, smooth, torquey, quiet and hopefully lasts 20 years to make the cost economical compared to the 2H engines that were only lasting a few years.
- PeterVWsuby
- Brumby Kid
Sounds like you should have put a 2H in it. Those things will run on 2/6 cylinders and unlike a subaru motor you don't have to worry about or fix your problems straight away lol
Love an old 2H toyota diesel!
Nice to hear your story Peter, but I do ask one favor... can we see some pictures?
Cheers Cam
Cheers Cam
