Advice on my second hand H6
Venom
Post by Venom » Fri Jul 04, 2014 12:33 pm
So i ordered a S/H motor from Japan with 80,000km on it which I picked up yesterday. I have a complete gasket kit from Subaru, obviously won't use the whole thing but I wanted everything on hand just in case.
Would like some advice on what to inspect, replace etc etc.
Fairly sure the 80,000km will be genuine or very close considering it was cruising around a little inland with a 100 odd million people on it.
Now my current motor both burns and leaks a total of 1 litre of oil every 1,000km or so. What I want to avoid is this degeneration with my newish motor. Suspect a lack of valve adjustment (I never did it) has led to a reduction in clearance, leading to burnt out valves resulting in burning oil. Timing chain and valve cover also leaks. Low engine oil has led to increase wear of the timing chain and it has death rattle on start even when warm.
So on my to do list so far:
Valve cover gasket kit replacement, including some cool aluminum half moon gaskets.
Measure valve clearances and adjust if necessary
Remove timing chain cover and reseal
Inspect timing chain guides for excessive wear, correct clearances, etc.
New spark plugs
New thermostat (factory)
Is it worth pulling heads? What should I check to see if i need to?
Compression on all cylinders is between within 5psi.
Some oil on the spark plug threads, but doesn't seen to be too much build up on the plugs.
Looks like standard varnish in the valve covers. No sludge and doesn't appear to have been cleaned by the seller (easy to wipe off myself).
The whole point of getting a second hand motor was so I could prep it as much as necessary with no time constraints. However would prefer to avoid unnecessary cost and work (like pulling heads) if I don't need to.
And pictures, because it's the internetz.
Seller has written compression test results on the fuel rail covers. Its in mpa so should actually be 1.20 - 1.25 not 12.0 to 12.5. So in psi that should be 175 to 180. They are a reputable wrecker according to Import Monster.
I checked the sale page and read the gauge to clarify ;)
RH side
Small amount of oil present on all RH spark plugs.
Venom
Post by Venom » Fri Jul 04, 2014 12:47 pm
H6 valve check and adjustment guide found here:
http://subenews.deej.net/wiki/index.php ... ntable=yes
I'll copy and paste here for future reference.
From Subenews
Valve Adjustment Check Procedure
Measuring valve clearance is pretty easy. Not quite as easy is removing the necessary stuff and then the valve covers, still not too bad though.
I'll try to do this as a step-by-step procedure. It will be for an early H6 because that's what I have and have experience with.
THE ENGINE MUST BE COOL, Wait at least a couple of hours before taking any measurements.
1. Remove all of the fittings, brackets etc. that are attached to the valve covers.
2. If needed, remove the fuel rails. I made custom ones and I had to remove them. You can probably just remove the 2 mounting bolts on each rail to provide wiggle room to remove the valve covers.
3. Remove the m6 valve cover retaining bolts. I needed a 10mm wrench.
4. GENTLY pry the valve covers off of the head. The factory uses RTV in the hard to seal areas like corners and this makes removal a little challenging. It will probably take some creative maneuvering to get the covers off what with all of the motor mount and other stuff in your way. It's best to simply remove or loosen items rather than fight with them.
5. Store the covers in a safe place.
The following may not be the most time efficient way to do this, but I do it this way to avoid confusion. By the way, ALWAYS turn the engine in its normal direction of rotation.
6. Locate the front left INTAKE valve pair. They will be immediately under the intake manifold runner.
7. Rotate the engine until the cam lobes that actuate the valves are directly opposite the valve, that is, the heel of the cam, not the lobe tip, is facing the valves.
8. Using a set of feeler (thickness) gages, determine which one will slide between the camshaft and the valve adjusting shim. The thickness of the gage that will fit between them with a couple of ounces (60 grams for you metric types) of force is the valve clearance. If one gage is too tight and the next smaller one is a little too loose, close enough, pick the one that you think is the best fit. For the early H6, Subaru says the clearance for intake valves is .008" plus or minus .0016", so anything between .0066" and .0096" will be in spec. I tend to set valves on the loose side in engines that run hard (ours do). I would prefer .009 to .010".
9. Write down the measured clearance for the intake valves at that cylinder.
10. Rotate the engine until the center INTAKE cam lobes are pointing directly away from the valves. Go to step 7 and 8 and do them again. Remember to write down what you measure.
11. Rotate the engine so that the cam lobes are pointing away from the INTAKE valves and do steps 7 and 8 once more. Write it down.
12. Go to the other side of the engine, front, INTAKE, an do the same thing you did for the left side. Seems to be a theme of some sort here, doesn't there?
13. Now for the exhaust valves. Start at the front left again, locate the exhaust valve pair, and measure the clearance. Subaru says .0098" plus or minus .002", or .0078 to .0118". I would shoot for .011 to .012".
14. Now that you have all of the clearances recorded, locate any numbers that fall out of the desired specs. Now the fun begins, so pay attention.
15. Lets say you have an INTAKE valve with .004" clearance (You are shooting for .010").
You want to increase the clearance, so subtract .004 (measured clearance) from .010 (desired clearance) and you find that you need to increase clearance by .006".
If the measured clearance was .012", you would want to decrease clearance by .002"
Here's the hard part. You will need an official Subaru Shim Replacer Assembly, available at your local Subaru store, or some kind of home-made tool that will allow you to remove the shim that resides just under the cam lobe.
Once you have the tools you need to remove the shim, remove the shim ion question and measure it's thickness.
Lets use our .004" clearance valve as an example.
Let's say the shim you removed is .103" thick. You need .006" more clearance, so you need a shim .006" THINNER than the one you removed, or .097". Pretty easy, huh? Go through all of your out of range valves in this manner and write down a list of the shims you have and a list of the shims you need. With any luck, you'll find that some of the removed shims will work in places where you removed other shims. A trip back to your friendly Subaru store will complete your shim list. By now you probably know the Subaru parts guy pretty well.
An alternative to purchasing shims might be to have the old ones ground down by a friend with a surface grinder. It is absolutely necessary that the shim faces are parallel and have a fine finish, so don't try to rework them on a belt sander or bench grinder. Of course, grinding them only works if you need thinner shims.
16. Install the new shims into thier appropriate valve assemblies and REMEASURE THE VALVE CLEARANCE. Don't assume for a minute that you did the math right, got the shims in the right place, or did anything else right. If all is right, you're a hero and can go on to the next not so adventuresome step.
17. Clean the valve covers. Remove the gaskets carefully (they're reuseable) and clean them too. Don't use a strong solvent on the gaskets but get all of the old sealant off of them.
18. Clean the cylinder head gasket surfaces. Don't scratch them.
19. Install the gaskets into the grooves in the valve covers. Make sure they are seated fully and properly.
20. Apply a high quality RTV sealant ( Subaru recommends Threebond 1280B, don't use generic stuff near oil, it will leak) to the corners of the mating surface on the head and install the valve cover. Try not to smear the RTV while doing this; you could cause a leak.
21. The screws that hold the valve covers on are shoulder-type and meant to be to torqued to 4.6 lb-ft (6.4 N*M). They are designed to be fully tightened against the shoulder and will not allow the gasket to be over compressed.
22. Once you are happy with the cover installation, reattach all of the stuff you removed, start the engine and check for leaks, strange noises tools left inside the engine, etc.
23. If all is well, enter what you did in the log book and go fly.
24. Considering the valve clearance news of late, I plan to make either 50 hour or annual valve clearance measurement a part of standard maintenence procedures.
Mike T.
Retrieved from "http://subenews.deej.net/wiki/index.php ... tmentCheck"
This page was last modified on 29 January 2010, at 16:21.
Content is available under Public Domain.
justincase41
Post by justincase41 » Fri Jul 04, 2014 7:24 pm
I got my import low km motor running the other day, supposed to only have 61,000km from new............. Burns more oil than a westie doing burnouts in the Curtis street car park (im a former ballaratian)
Its been sitting around for the past couple of years so I am suspecting that the rings are all gummed up, seized and what ever else is wrong.... Oh removed the water pump to find the a large chunk salty looking rust in the water galleries..... Maybe to much sake once night for old mate Mr Kudo san and drove his car into the sea of Japan........ Next stop....Australia jap import motor supplier
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
Post by El_Freddo » Sat Jul 05, 2014 10:33 pm
Dunno mate, if it's got 80k on the clock, replace water pump, some oil seals and off you go I reckon.
Or remove heads and do the gaskets while it's out. Or better still, do the above, drop it in, drive and do up your current engine to either move on or have on the shelf with Murphy ensuring it'll be there for the life of the vehicle...
