Ea81 dizzy wiring- single wire
Xp_weapon
Post by Xp_weapon » Sat Apr 26, 2014 3:08 pm
Hi there I've got a problem with a off road buggy I'm fixing up
I've just swapped a ea81 engine into it
But I'm having trouble with dizzy an coil wiring
My dizzy has one single blue wire on it, all other threads I've red say there's susposed to be a yellow an a black an white
But I have a single blue wire running from bottom of dizzy to near the dizzy cap
Any idea if this is susposed to go to + or - on coil?
I'll try post a pic, will explain it better cheers guys
Xp_weapon
Post by Xp_weapon » Sat Apr 26, 2014 3:12 pm
Pic of dizzy any one know what type it is an what coil should be used
Post by Silverbullet » Sat Apr 26, 2014 4:01 pm
That's a points based dizzy so it won't have the yellow and black+white wire. With points based you need a points type coil with external ballast resistor. Only electronic ignition units have 2 wires going to the coil (electronic ignition coil, with no ballast resistor) That blue wire goes down to the condensor which should be attached somewhere at the bottom of the distributor. Where that blue wire ends up top there is another spade terminal which should be connected to the negative side of the primary terminal on the coil.
Hope this helps! :) Also post pics of the buggy ;)
Xp_weapon
Post by Xp_weapon » Sat Apr 26, 2014 6:02 pm
Thanks mate really appreciate it, now since I removed the dizzy how do I go about reinstalling it, in relation to timing?
Getting the rotor in correct spot to cylinder at tdc ect ?
Thanks again
Post by steptoe » Sat Apr 26, 2014 6:08 pm
first step is to get #1 on its TDC of compression stroke, then I shift to timing mark on flywheel, say 10 DBTDC.
Work out where the #1 lead goes to on the dizzy cap, and which way it goes on, point rotor in rough direction, drop it in, see if it lines up. Think the points should be open, rotor pointing close to its terminal inside cap. Might start !
Xp_weapon
Post by Xp_weapon » Sat Apr 26, 2014 8:12 pm
Thanks mate will give it a go tomorrow
Had a quick look on the fly wheel for timing marks
But couldn't see much
Will have to try clean up flywheel tomorrow
Thanks again
Post by RSR 555 » Mon Apr 28, 2014 11:30 am
Oh.. another thread.. well I replied in the other one.. sorry
I would also like to add the firing order is 1,3,2,4
I'd also say once you've cleaned up the flywheel timing marks, then just get a white paint marker and make a mark in 8 degrees before top dead centre.
Xp_weapon
Post by Xp_weapon » Wed Apr 30, 2014 10:49 pm
Thanks for all the help guys
I got it sorted out, planing on up grading to electric ignition soon
Points will do for the mean time now
