Brumby Clutch
badga880
Brumby Clutch
Post by badga880 » Tue Apr 22, 2014 7:29 pm
Hi all do any members know a good reputable place for a clutch to suit a 5 speed in a brumby. Also need some front and rear main seals and some manifold gaskets inlet, a couple of rocker cover gaskets any advice appreciated.
Thanks
Post by steptoe » Tue Apr 22, 2014 7:38 pm
Watch what you ask for...if still EA81 the flywheel step in use and the step required by the pressure plate needs to be considered. You might try a clutch sales specialist to get the bits separate, or them sell you an L Series EA82 friction plate to add.
You need to know if you have 200 or 225mm flywheel as you can have either.
Factory sent EA81s out in 200 & 225mm both with 23mm step. If you have EA81 and 200mm you may have a Gemini friction plate hanging off the boxes splines !
All EA82s got 21mm step in 4WD boxes and EA82 T FWD at least.
If you have EA81 and 225mm flywheel, just an EA82 4WD or turbo clutch kit and ensure the flys step is 21mm and you should be fine :)
And , need to watch the throwout bearing to see it pushes on the tips of the clutch pp fingers and not 10mm further out like mine was for 9 years ! harder and bit easier to crunch if clutch foot gets lazy :(
Go genuine on seals and inlet gaskets. Aftermarket OK for RCG's
Post by El_Freddo » Tue Apr 22, 2014 8:36 pm
You really need to know if the 5 speed conversion has been done with the EA81 clutch and some hybrid throw out bearing or if it's a EA81 flywheel with EA82 clutch pressure plate and disc.
Or are you running an EA82 with the 5 speed? If so a stock EA82 clutch will do.
badga880
Post by badga880 » Wed Apr 23, 2014 6:05 am
Thanks for that ok will measure the fly the box came from Japan out of a Ea81 turbo looks the same as 82 box ahh! The joys of building toys, well actually it is my daily driver
Thanks will chase original seals and gaskets I will see what frog has. Thanks again
Return to “Wanted”
