2003 Forester.... Rear (SLS) Suspension Question?
EB#
Post by EB# » Fri Mar 28, 2014 2:25 pm
Hi there,
I have a standard 2003 Forester 2.5 (05/03 build) and was just wondering
if this model has the 'self levelling' rear suspension or not. I am assuming
that as it is not the XT (or other top end model) that it does NOT have
SLS.... Correct? How do I tell in this instance?
I am looking to replace the rear shocks and will likely go with a pair of
KYB units.
Thanks.
yarney
Post by yarney » Fri Mar 28, 2014 4:07 pm
They shouldn't be, The easy way to check is to have a look at the strut there should be a canister along side the main part of the strut
In where the spring is. That is the self leveler if there is no canister then they are normal
Jan
Subyroo
Post by Subyroo » Sat Mar 29, 2014 1:03 pm
EB# wrote:Hi there,
KYB units.
Thanks.
My stock 2003 XS Forester 2.5 (04/03 build - still within the family circle) has SLS on the rear end.
Peter
EB#
Post by EB# » Sun Mar 30, 2014 4:34 pm
Thanks Yarney....
I had a look and they are a standard shock body without the additional cannister on my 03 Foz X.
I scoped around on the web and found a pic of the SG SLS rear shock, just for comparison.
