Hi all, I have decided to do a head gasket job on the liberty wagon.It is leaking really badly on number 2 and 4 cylinders.My question is where do I get a gasket set for it?I have seen a kit from the states with all sorts of gaskets in it for just over $100 aussie dollars,is that a good deal?and what do you think about the quality of the product?Or should i just get a head gasket only from a Subi dealer?
And also does anyone recommend a machine shop in sth east melbourne to reface the heads?
http://www.ebay.com.au/itm/90-98-2-2L-S ... d2c41095f#
Cheers Robby.
EJ22 head fix
G'day Nobby,
I'd contact FROG and see what he can come up with for you. If that doesn't fit your budget look for a kit from a company you know/"trust". I've also been recommend "the import experts" as a seller on the US ebay.
While you're at it change your water pump - I didn't and I'm paying for it in extra downtime on the vehicle
Also a good time to put in a cam belt kit (can be purchased with a water pump) if you don't know the history of the engine.
I have already done the water pump and timing belt & pulleys and all of the leaking oil seals,so I am really only needing the gaskets for the two heads.Or whatever else I may need for the head work.
I have never done this before and I am looking at doing it with the engine in the car.And YES i know it will be a pain,but I have no engine lifter so I am going to give it a go and see what happens.
Am I mad or can it be done??
Regards Robby.
Regards Robby.
