differing redLines ??
Post by steptoe » Sat Feb 01, 2014 8:15 am
Just looking at a tacho , suspected out of a slushbox L Series (auto) NA 3 speed FWD
It has broken redlines starting at 5500rpm. I thought they went to 6500 before any red, so looked at my other L Series that started out life as a slush box as well, just a turbo added in the factory :) , to find it is as I thought - 6500rpm redline.
Different redlines between NA and turbo ? Manual to auto ? year to year with the L's ??
What's your model & redline?
Subydoug
Post by Subydoug » Sat Feb 01, 2014 10:17 am
1986 FWD vortex. Motor is an mpfi ea82 non turbo. 3 plug ecu. Redline is at 6500rpm. Cant say ive had it much over 6k though. Wouldnt wanna unleash all that power on the poor unsuspecting road :D.
Doug
Maxed out ...
Post by Bantum » Sat Feb 01, 2014 4:16 pm
Most Brumby's don't have a tacho so NFI what its rev limit is, the '82 Touring Wagon does however : starts at 5500 & goes to 8000 rpm max ... :p
Cheers, Bantum ...
Post by NachaLuva » Sat Feb 01, 2014 4:49 pm
Bantum wrote:Most Brumby's don't have a tacho so NFI what its rev limit is, the '82 Touring Wagon does however : starts at 5500 & goes to 8000 rpm max ... :p
Cheers, Bantum ...
Crikey look at all those gauges! :twisted:
Post by Gannon » Sat Feb 01, 2014 5:30 pm
6500 on my RX turbo manual.
Post by RSR 555 » Tue Feb 11, 2014 10:02 pm
All of the turbo models have higher RPM redline but don't know why but at a guess, I'd say it's due to them not boosting till higher in the rev range.
My original L.Series (which I brought new) was the best reving engine NA engine until I drove Jayson's little 1600 2 door sedan. That is a little rocket with the EA71 but no tacho to see what it's doing
Wooster
Post by Wooster » Wed Feb 12, 2014 11:43 am
Aaah Redlines & R.P.M. The Galactic Light Speed Red Rocket has one it stands for Reactor Particle Manipulator, in lay terms somewhat similar to nuclear fission but with a G restraint and multifocal redline shifter.
I was advised by the interplanetary Klingon salesman,person, being, thing at Autobarn that this very rare item is indeed essential when phasing through the space time continuum, orbital re-entry, emergency avoidance of solar flares, for calculating warp speed and when exiting black holes...unfortunately it's after market!
PS , I’m considering taking orders for those interested in such adventures
Post by RSR 555 » Wed Feb 12, 2014 11:28 pm
Can I have some of that stuff Ray? :p
Wooster
Post by Wooster » Thu Feb 13, 2014 12:15 pm
Carton each mate, Toohey New or Coopers Pale Ale preferred, but I am quite partial to Emu Export
Post by RSR 555 » Fri Feb 14, 2014 1:02 am
Not the Emu Export.. anything but that
Esubie
Post by Esubie » Fri Feb 14, 2014 4:25 pm
No Tacho at all on my '85 L Wagon NA manual.
1985 L Wagon DL. Carb. EA82. Stock.
Post by NachaLuva » Sat Feb 15, 2014 11:33 am
RSR 555 wrote:All of the turbo models have higher RPM redline but don't know why but at a guess, I'd say it's due to them not boosting till higher in the rev range.
Perhaps they have different hardened/nitrided pistons, conrods, crank? I know with the XTs & WRXs, Subaru kept changing how they treated these
dwayneb
Post by dwayneb » Mon Mar 03, 2014 10:55 am
I was under the impression for the brumby's where there was just the speedo, the numbers in the circles where were the redline was, and from my understanding it was 5500 RPM for redline, although never had a tacho
Subydoug
Post by Subydoug » Mon Mar 03, 2014 12:08 pm
Fun fact I only noticed the other day, with the ea81 4sp man, in 3rd gear the tachometer and speedo needle point at the same angle, where as in my vortex it's 5th gear. Donno if all cars and tachometers are setup to do this but I thought it was cool.
Doug
coxy
Post by coxy » Mon Mar 03, 2014 7:40 pm
Factory twin carb EA 81's need a 10K tacho according to one of possums old mechanics
Post by steptoe » Fri Mar 07, 2014 11:04 pm
OK, seen 6500 on the EA82M once or twice now, and no think it much of a good idea. Second is the gear to try it anyway :) Think it was just nudging 5500 or 6000 when I hit 80 kph in second, reaching for third and by my side was an early EJ22 Lib and P plate looking driver - I hope he was trying hard also :D . So, this donk goes better than my old EA81TC and is quieter, more so when that clutch fan is turfed in favour of a slim line 52mm Davies, Craig sold panasonic fan.
FujiFan
Post by FujiFan » Fri Mar 07, 2014 11:53 pm
OK, seen 6500 on the EA82M once or twice now, and no think it much of a good idea. Second is the gear to try it anyway Think it was just nudging 5500 or 6000 when I hit 80 kph in second, reaching for third. So, this donk goes better than my old EA81TC and is quieter,
Way to go Jonno;) EA82's have been known to go really well in the right hands!
Hmmm, yes they are basically panasonic motors in dressed up:p
J.
