I have just aquired a 1999 liberty (BH?) and as a lot of the driving it does is on dirt roads I wanted to upgrade from the standard 195/60 15. I have some 205/70 15 A/T Bridgstone Dueler on another car and was wondering will these foul the guards/suspension?
The car has standerd ride height.
George
						tyre sizes for a 1999 liberty
- TOONGA
George you will new tyres will be 2 inches taller in circumference and not much wider than the 195/60 15's.
this tyre calculator will show you the size difference. http://www.miata.net/garage/tirecalc.html
If you are using the latest version of Java you will have to add it to the exception list in the java security console to get it to work, and Java will kick up a fuss as it isn't a https site. (overkill)
- stephendean
My friends 99 Outback (BH model) has 215/60R16 on it and let down to 15psi on the beach and it runs perfect but this car has a 40mm lift over the standard Liberty. I would look at buying a 1" lift block kit for your struts and then fit 195/70R15 tyres.
