hi, i'd like to find the simplest source of door lights power souce to add some footwell lighting. There is the back of the light switch not so easy to get to, then there is the light itself in the back of the roof.
does anyone know of an easy to get at wire to latch on to?
think at same time i need a lights off after so many minutes device - say from jaycar ....
t.i.a.
EDIT - so i don't give the wrong idea, the intention is to get footwell lighting with door open light in roof. If I were to tap off the park light circuit - that would give me footwell lighting only when light switch is on - giving off nuisance lights while driving.
I think I can expect to find desired wire behind interior trim side of front windscreen
find interior light wire of brumby ?
Usually the cigarette lighter is illuminated and is pretty easy to get to
Gees, down behind the right kick panel, wires disappear into the hollows - think I found the wire you are after in there - made up an ignition key illuminator with a tiny bulb and green cover - both fall out over time. An upgrade would be a dirty fat 10mm LED
The wires are under that cover to the side, think black and black/white trace ?
