Points to electronic
G'day guys,
Can anyone point me in the right direction of a link of someone doing the points to electronic dizzy swap on an ea81?
Heres my thread mate,
showthread.php?t=23871
You dont need to use an ignition box like I did, I just used what was available to me. I suspect the electronic ignition coils have that all built in so just getting one of those and swapping it would probably be easier.
Doug
Doug
- Silverbullet
Make sure you get the wires at the coil the right way around as in + and - I think there's one wire that gets power only when turning over, one for normal running and then the two wires coming from electronic module in the dizzy. I couldn't figure out why mine wouldn't start then realized I had the crank power wire on the wrong side of the dizzy
A decent multimeter helped solve the problem.
From memory the Electronic dizzy has 2 wires coming off it. One black with a white strip (+/positive) and one yellow wire (-/negative) and you must also change the coil to suit plus remove the ballast from the system.
