Brumby EA82T turns itself off
I recently purchased a Brumby with an EA82T fitted . Mostly it runs very well but twice now it has turned itself off while on the road. Each time I have been able to pull over without problems. It then restarts straight away and off I drive. What should I look at to try and solve this problem? Thanks, Steve.
G'day Steve,
Where to start on a purchased conversion? There could be so many issues, some that I can think of are:
- an immobiliser issue if there's one fitted
- an intermittent cut in power to the ECU
- an issue with the crank angle sensor - long shot, but the ECU may reset when you go to re-start the engine, thus ignoring the sensor issue or not having the issue since the reboot.
There could be a wiring issue or an earth issue that has become present in the system since the conversion.
One question - is the conversion running the stock ECU or an aftermarket ECU?
PS: welcome to the forum!
Do the dash lights stay on (oil pressure, charge and ecs light) when it stalls or only after you turn the key back on?
Could be a dicky ignition relay
This was my first thoughts too.. I would like to know if you get any indications of things working or not working, i.e. tacho, fuel pump, etcGannon wrote:Do the dash lights stay on (oil pressure, charge and ecs light) when it stalls or only after you turn the key back on?
Yeah dont stress mate, these guys are good at problem solving on the older Subies, as long as you can give them all the info they needSteve wrote:Thanks for your replies. You have given me pointers to look for . I appreciate your quick replies as it has helped lower the stress level. Steve
