Fuji Tractor ...
Fuji Tractor ...
Post by Bantum » Fri Dec 20, 2013 6:22 am
Ok - here it is, the Fuji Tractor ... :)
So I've been working on this since I saw this sketch :
More on the the Squirt here : showpost.php?p=218725&postcount=10
Basic idea was to use the chassis / driveline off a Impreza or similar & shorten it. Then put some new body work over the modified chassis. haven't worked out all the details, as is only a concept at this stage.
Will post some more images / details later ... ;)
Cheers, Bantum ...
More ...
Post by Bantum » Fri Dec 20, 2013 6:27 am
Some more images :
Cheers, Bantum ...
purp
Post by purp » Fri Dec 20, 2013 6:58 am
Should be able to get the lawn cut in record time.... :)
Post by TOONGA » Fri Dec 20, 2013 7:45 am
nice concept and a very well thought out drawing
this guy in NZ took it a little futher minus the blades :) (video 1)
and Honda made one that goes 130mph (video 2)
http://www.youtube.com/watch?v=Qe_mS_ucYCM
http://www.youtube.com/watch?v=oH_Qb4fdHfg
Post by NachaLuva » Fri Dec 20, 2013 2:54 pm
The Poms have wicked lawn mower races...big deal over there lol ;)
Post by Bantum » Sat Dec 21, 2013 1:46 pm
Yeah, It should be good for doing quick laps around the paddock ... :)
However, I'm not sure about the mechanicals to drive the cutting blade/s though. I was thinking of some sort of prop shaft to junction box behind the Subi gear box, it would need a transfer box of some type there ... Any body got ideas ... ?
Cheers, Bantum ...
Battlewagon
Post by Battlewagon » Sat Dec 21, 2013 6:02 pm
Power steer pump and small hydraulic motor, use a bypass spool on the control so it wont lockup the pump...done.
Post by Gannon » Sat Dec 21, 2013 6:18 pm
You will need a bigger pump than a PS pump to run the blades.
Also, how will you address the lower gearing needed to make the tractor practical?
Turbo diesel engine would be the engine of choice, but I think the gearbox will have to be one built for tractor duty
Post by Bantum » Sat Dec 21, 2013 6:23 pm
Battlewagon wrote:Power steer pump and small hydraulic motor, use a bypass spool on the control so it wont lockup the pump...done.
Thanks Mate, just what it needs for it to be completed ... :)
I hadn't thought of it but this sounds like the perfect solution, although I will have to do some research on the components as I've never really dealt with any of that sort of stuff ... ;)
Got any hints / details / links on what components I should be looking at ?
Cheers, Bantum ...
Geared ...
Post by Bantum » Sat Dec 21, 2013 6:39 pm
Gannon wrote:... You will need a bigger pump than a PS pump to run the blades ...
Hmm, my thoughts were if you had an electric operated oil pump going to blade motor ie: independent from engine - you could run one for each blade, plan is for two - is this doable ?
Got any other solutions ?
Gannon wrote:... Also, how will you address the lower gearing needed to make the tractor practical ... ?
If I were to keep it in the Fuji family, sounds like having to find EA dual range low gear set, or similar - another option would be to find a tractor donor gearbox that could be mated to the Subi Engine ... ;)
Gannon wrote:... Turbo diesel engine would be the engine of choice ...
Yep, Another solution might be the new XV electric Hybrid, as the electric motor should be able to handle low gears ... :)
Cheers, Bantum ...
Post by Gannon » Sat Dec 21, 2013 7:23 pm
Bantum wrote:Hmm, my thoughts were if you had an electric operated oil pump going to blade motor ie: independent from engine - you could run one for each blade, plan is for two - is this doable ?
It would be largely inefficient. Why not run the blades directly from electric motors?
The problem then is that you need one hell of an alternator to run them. A 1.2hp 12v electric motor will pull over 80A, but you will need in excess of 20hp worth of electric motor to turn blades as wide as the car. Do you have a 1000A alternator handy.
Mechanical drive is the only way to do it.
As for the reduction, if you want to stick with the subaru gearbag, you want at least a 2:1 reduction between the clutch and the gearbox, more likely a 3:1
Deck it ...
Post by Bantum » Sat Dec 21, 2013 11:01 pm
Gannon wrote: ... Why not run the blades directly from electric motors ?
Yep - that might work ... :shock:
Note : 36 volt 3600 rpm, (or 1/2 HP - 2400 rpm on 24 volt, or 1/4 HP—1200 rpm on 12 volt).
More motor details here : http://www.kansaswindpower.net/GE%20Ele ... actors.htm
As for the number of blades, I was thinking two originally. But after bit of research concluded that three would be better for coverage & cleaner cut, where blade overlap is greater than many conventional decks ... eg :
Could also do the traditional belt & pulley system :
More details here : http://salesmanual.deere.com/sales/sale ... _x700.html
Gannon wrote: ... You want at least a 2:1 reduction between the clutch and the gearbox, more likely a 3:1 ...
Yeah - sounds good, just have to find the right one ... :p
Cheers, Bantum ...
Post by Gannon » Sun Dec 22, 2013 5:56 am
I wasnt being serious about the electric motors, just using it as an example to show how much power would be needed to drive an electric oil pump
Battlewagon
Post by Battlewagon » Sun Dec 22, 2013 8:07 am
Why not lose the weight and complexity of the gearbox altogether, go for a hydraulic pump mouted direct to the bellhousing, and mount hydraulic motors directly to the diff on the rear and wheels at the front?
No heavy gearbox, cv shafts, gearshifts to modify, and it lets you locate the engine a tad further rearward, improving stability.
Thats how some of the big commercial mowers work.
Also gives you more than enough hydraulic supply to run the blades.
You may need to mount a cooler for the hydraulic fluid.
Video ...
Post by Bantum » Mon Dec 23, 2013 11:16 am
Thought I'd give the video a go :
Also gave it a bit more detail ( low res though ) ... :p
I ended up going with electric motors in the cutter for now, as it seemed the easiest to do ... ;)
Add: I will also post this up on 3d warehouse later ... :)
Cheers, Bantum ...
Fully Loaded ...
Post by Bantum » Thu Dec 26, 2013 1:47 am
Ok - I've finally managed to get it loaded up to 3D Warehouse ... :cool:
( I did have problems with selecting editing items on their site for some reason )
So Here it is, Enjoy : Fuji Tractor ...
Cheers, Bantum ...
