Brumby torsion bar adjustment
Donders96
Post by Donders96 » Thu Nov 28, 2013 11:32 pm
Hi all, just wondering how much adjustment I'll get out of my rear suspension in my 88 Brumby, I've heard a few different numbers but the general idea seems to be about an inch both up and down, and I've heard of the welding onto the bolt trick, but I want to know if I can drop the rear by about two inches without modifying too much, I know I can adjust it down but I want to know of any other ideas floating around about this
Cheers - Rob
Post by El_Freddo » Fri Nov 29, 2013 5:46 pm
If you want it lower loosen the bolt off.
If that's not enough you can remove the torsion bar and "clock it" a tooth or two up or down until you're happy with the ride height. After that you've got to look into shock setup...
Going for a lowered brumby are you?
Donders96
Post by Donders96 » Fri Nov 29, 2013 6:22 pm
I'm just sort of wondering how much adjustment I'll get, and if I take the bolt all the way out will it be a bastard to get back in or not
Yeah, it's RWD, locked diff, exhaust dumping straight out under cab, LED valve caps, got all the goods inside, soon to be lowered, maybe convert to a 5 stud so I can get some nicer/bigger rims to make it look a bit lower and better, thinking about 4-6" stainless stacks, some HID driving lights or a light bar, big tough bullbar, and looking at a turbo setup for maybe mid next year
Cheers - Rob
brumbyrunner
Post by brumbyrunner » Sun Dec 01, 2013 6:29 am
The rear torsion bar adjustment provides about 3" of ride height variation. You can safely remove the adjusting bolt but that would allow water and crap into the housing. Just back the bolt out until theres no pressure on it, and leave it in there.
Settlement Creek Racing
Donders96
Post by Donders96 » Sun Dec 01, 2013 8:47 pm
So from all the way down to all the way up is about 3"? And yeah I was worried if I couldn't get it back in then I would get it full of crap haha
Thanks for you help, I appreciate it :)
Cheers - Rob
