Thermo Switch- EA81 Brumby
Guys, other than removing the thermo switch to check it's serviceability does anyone know of an alternative method.
The fan works when run direct from the battery, however I'm not confident that the thermo switch is kicking in
Thoughts?
Ray
Thoughts?
Ray
Try running the fan by having the ignition on and take the wire to the sensor off, then touch the wiring to a good earth point. This should make the fan come on and if not, then you might need to check the wiring. If this works and the fan comes on then it could be a faulty sensor. I do know they come on very late though, so could be ok.
I like to run a wire from the back of the sensor (leaving the original wiring as factory) and run this wire inside the cab to a switch, then off the other side of the switch to earth. This allows me to bring the fan on earlier which works great when you're running on the beach
- Bantum
Thermo Test ...
One way of checking if your old thermo still works is to remove from car & run some boiling water over the sensor part ...
Note : You'll need to set up a 'third hand' + attach a test circuit, with some sort of indicator like a light bulb, multimeter etc ...
Caution : I'd only advocate doing this with adult supervision ...
Cheers, Bantum ...
Cheers, Bantum ...
Funny, must be planned obsolescence kicking in, one of my Brumby switches just gave up connecting the fans recently.
Wonder if it is part number 682151180 - it is stamped 98*C and sits in remote storage for FROG.
I once hooked up a switch for one of these fans, taped it to the kick panel near bonnet release - mate ! the heat that switch carried ! I'd suggest relays as well !
- Silverbullet
There shouldn't be any heat/draw from that wire, as the sensor is just a switch to earth, so no relay needed. If your switch was getting hot, it was because of too much current draw, thus meaning your fan was on it's way out.steptoe wrote:I once hooked up a switch for one of these fans, taped it to the kick panel near bonnet release - mate ! the heat that switch carried ! I'd suggest relays as well !
Very good find.. need to add this to parts threadSilverbullet wrote:They're not that hard to find
http://www.ebay.com.au/itm/Tridon-Therm ... df0&_uhb=1
Was on its way out some ten years ago ? Still going real well !! Was quite a heavy duty sort of metal toggled switch providing direct earth for fan rather than a relay perhaps ? Or my choice of wiring gauge at the time ?? Thought I had just T pieced in on the one wire to the switch on the radiator - and now that I look the rad has a choice of single round pole switch and then there is a twin male spade switch directly below - must tinker with it one day.......
Jonno, you mush have either an aftermarket rad or an L.Series rad in there to have the 2 different senders. From memory, the single one was the old type where they just switched to earth when the water was at the right temp and the twin one was due to the later ones having plastic tanks and now requiring an earth from another location.
Awesome Ray, glad to hear you're happy with the weber conversion.
When is your next trip over to the west?
