EA82 Part No's
Kalbarri_baru
EA82 Part No's
Post by Kalbarri_baru » Mon Oct 28, 2013 2:12 pm
Heya all,
I hate going to an auto parts store and ending up with the wrong parts for my (Petrol, Manual, Carby, 4wd 93 L series wagon with an EA82), the most common problem I am faced with is ending up with Liberty parts as the auto shops have a hard time finding a 93 L series.
If you are having the same probs then I can help a bit by listing part No's for the vehicle I have listed above in red.
The easy way to avoid wrong parts is ask for the parts by engine code eg: EA82 or even better if you write down your VIN (Vehicle ID No) and take that in to the auto parts store.
Ok the parts listed below in no particular order.
Spark Plugs (NGK) BP6ES
Air Filter (Ryco) A337
Oil Filter (Nippon Max) WZ493
Fuel Filter (Repco) RPF1020 can use (Z427)
Leads (Top Gun) TG4486
Rotor JR527
Water Pump (Repco) WP3033RP
Distributor Cap (Subaru Genuine) 22162AA000
Heater Hose IN (Subaru Genuine) 72006GA361
Heater Hose OUT (Subaru Genuine) 72006GA372
Rear Shocks L & R (KYB) 341216
Front Strut (KYB) "RIGHT HAND" 333232
Front Strut (KYB) "LEFT HAND" 333233
Timing Kit (Gates) TBKG00933 http://www.ebay.com.au/itm/GATES-TIMING ... b5e&_uhb=1
Radiator (Generic) http://www.ebay.com.au/itm/Subaru-L-Ser ... c7e&_uhb=1
Oils and coolants I use.
Engine Oil (Penrite) HPR 15, 15W - 60 (5 Litre)
Rear Diff Oil (Penrite) Gear Oil 80W - 90 (1 Litre)
Manual Gear Box Oil (Castrol) Manual VMX 80W (4 Litre)
Coolant (Tectaloy) 60 Plus (4 Litre).
Nolathane Bushes http://www.nolathane.com.au/do_segue.ph ... 985-6%2F94
Alternator Bosch 50amp + 60amp http://www.autoelectricsdirect.com.au/i ... &cat_id=33
Feel Free to add to this list, if a decent parts list appears then I will convert all user entries to a PDF so it can be downloaded for printing out and kept in the glovebox.
Hope this helps.
WayneO........................
Post by steptoe » Mon Oct 28, 2013 4:30 pm
For those with mpfi EA82 the spark plugs to use a BCP6ES - if that is correct, emphasis is on the C - uses smaller 5/8" plug socket as the plain jane BP6ES uses larger 13/16" socket that can catch on the casting
Other part numbers for EA82
Bosch GH617 mpfi turbo dizzy cap 10/85 make date, 3/87 compliance date GLTA red
Bosch GH623 mpfi turbo spider 4/87 compliance Vortex EA82T dizzy cap
Bosch GH605 is a dizzy rotor
E84189 Eagle Performance Eliminator HT lead set for mpfi and turbo EA82, Spiders different - made to measure
HOSES
top radiator hose EA82 Mackay brand CH2603
bottom rad hose is Mackay brand CH2604
GASKETS
genuine sump gasket 1121AA001 - about same price as aftermarket supplier
MISC
Clutch throw out retainer clips on fork 30539AA000 CLIP-CCH SLEEVE
ENGINE SEALS
front oil seal ................806738070 cross ref 38x59x9 mm
oil pump shaft seal........ 806718090 cross ref 18x30x9mm
camshaft oil seal............806738040 cross ref 38x55x9mm
cam seal carrier O ring ...806958020 cross ref 58x2mm
__________________
Another thing to add here would be torque settings ?? Given that if find self in here chasing part numbers you might also be needing torque specs on nuts and bolts to complete the job !
turbo to front exhaust pipe nuts 18-25 ft/lbs
turbo to dump pipe nuts 18-25 ft/lbs
cylinder heads exhaust port stud nuts 19-22 ft/lbs
water pump and viscous fan M6 nuts n bolts 6.7 - 7.7 ft/lbs
knock sensor 16-20 ft/lbs
spark plugs 13 - 17 ft/lbs
intake manifold bolts to head 13 - 16 ft/lbs
flywheel to crank bolts 51 - 55 ft/lbs + thread locker
clutch pressure to flywheel 9 - 12 ft/lbs + thread locker
timing belt tensioner to block 12.7 - 14.8 ft/lbs - not as tight as you woulda thought
crankcase torque - mild steel bolts into alloy casing , suspect not crankcase halves torque
M10 29 - 35 ft/lb
M8 17 - 20 ft/lb
M6 3.3 - 4.0 ft/lbs - getting into inch/lbs wrench terrritory !
Post by steptoe » Mon Oct 28, 2013 4:31 pm
M10 29 - 35 ft/lb
M8 17 - 20 ft/lb
Post by RSR 555 » Tue Oct 29, 2013 10:52 am
steptoe wrote:Another thing to add here would be torque settings ??
What's the part number for them? Isn't the post for part numbers??
Also would be nice Jonno if you could put your model of your car (like Wayneo has done in bold red), so others can refer to this post in the future.
Kalbarri_baru
Post by Kalbarri_baru » Mon Nov 11, 2013 10:00 pm
Genuine Subaru Oil filter, Suit all L series (part # 15208AA001).
Genuine Subaru sump plug washers (part # 11126AA000)
Kalbarri_baru
Post by Kalbarri_baru » Sat Dec 28, 2013 9:39 pm
NGK Iridium Spark Plug BPR6EIX (6637 = .08mm gap)
Not a EA82 part No below, but thought these additional part No's might help
GENUINE SUBARU L SERIES HEADLIGHT RIGHT 1985-1992
Part/No 84002GA250
GENUINE SUBARU L SERIES HEADLIGHT LEFT 1985-1992
Part/No 84002GA240
Post by steptoe » Sat Dec 28, 2013 10:25 pm
top radiator hose L Series EA82 in Mackay speak is CH2603 fits bloody nice as a top hose when fitting EA82 intake manifold on EA81 in Brumby
bottom rad hose is CH2604
Post by steptoe » Sat Jan 18, 2014 3:44 pm
CLIP-CCH SLEEVE
30539AA000
better known as the little paper clip looking clips on the clutch fork of L Series and EJ too I believe. Don't come with clutch kits, often shagged when uncovered resulting in a trip to Subaru
Post by RSR 555 » Fri Feb 21, 2014 10:18 pm
Front King Springs (30% stronger than standard Subaru ones)
P/N.. KFFS-45 (these also suit the fronts on EA81 models)
Rear King Springs (30% stronger than standard Subaru ones)
P/N.. KSRS-03
EDIT: These are for the L.Series 85-94 4WD wagon models
Post by steptoe » Sat Feb 22, 2014 9:16 am
does stronger also mean sits higher in kings case ?
Post by RSR 555 » Sat Feb 22, 2014 10:06 am
steptoe wrote:does stronger also mean sits higher in kings case ?
No. Height is the same but it has better load carrying capabilities
Point
Post by Point » Sat Feb 22, 2014 10:22 am
Do you mean KFFS-45 for the front? ( I just looked up the Kings catalog )
98 Forester GX
02 Forester XS Luxury
Post by RSR 555 » Sat Feb 22, 2014 10:46 am
Point wrote:Do you mean KFFS-45 for the front? ( I just looked up the Kings catalog )
Sorry, yes, they were supposed to be KFFS-45. All fixed
Insane
Post by Insane » Tue Feb 25, 2014 8:56 pm
Anyone know the part no for a starter motor for an EA82T using a 4wd box?
Post by steptoe » Tue Feb 25, 2014 9:51 pm
4WD auto or 4WD manual ? I think the autos were different - pick nncoolg's memory on this one - he got mine :)
Insane
Post by Insane » Wed Feb 26, 2014 4:18 pm
manual
Post by El_Freddo » Wed Feb 26, 2014 8:21 pm
Same as a non turbo EA82, carb or MPFI ;)
FujiFan
Post by FujiFan » Sun Mar 16, 2014 11:20 am
Heya all,
Rotor JR527
Subaru Geniune dizzy rotor: 22157KA020.
Also rear KYB's 341065 (136mm from center lower eye to lower spring seat) KYB's listing for these pre 87 model L's. Much harder to source than the 341216!
J.
Post by steptoe » Sun Mar 23, 2014 10:17 am
front oil seal 806738070 or for cross reference non sube seals 38x59x9 mm
oil pump shaft seal 806718090 18x30x9mm
