advice on timing belt kit
gazcull
Post by gazcull » Sun Oct 20, 2013 1:25 pm
hi , after a delay i decided to remove the timing belt covers on my 93 rs turbo motor to check out the condition of the stuff. check the pic ive attached , the bottom idler!!! really want some advice on the timing belt kit
A: belt, tensioner, idlers , seal kit 380 bucks
B: same as above but with hydraulic tensioner 500 bucks
C: same as above plus water pump 550 bucks
money is an issue but i will spend the big money if i have to,
any advice is appreciated :D
Post by RSR 555 » Sun Oct 20, 2013 1:41 pm
If money is no worries, then definitely go with option C, as this will mean you don't have to pull it apart for a while.
That lower idler is toast. I also see lots of crap/sand in the timing belt area. I'd look at replacing the seals that are around the covers, both the rubber ones and the foam ones behind the inner covers.
Also, how's the oil pressure? Just thinking that because you're right there, you might as well replace that too?? Oil pumps are fairly cheap off ebay and could extend your engine life :)
Post by RSR 555 » Sun Oct 20, 2013 1:44 pm
Oh and forgot to mention.. grab yourself a can of degreaser and give it a good wash down before replacing the crank and camshaft seals :)
STiAMV
Post by STiAMV » Sun Oct 20, 2013 4:44 pm
it balls flew from the bearing? haha , lucky belt is not jumped !
Changes along with the water pump, so after a while not disassemble again all because of water damage to the pump!
Subaru Forester EJ201 МТх2 JP 2001.-there are
Subaru Impreza EL154 SS EU 2008-there are
Subaru BRAT ЕА81 MTx2 EU 1989.-there are
STiAMV
Post by STiAMV » Sun Oct 20, 2013 4:47 pm
Yes, here I also support, if you have money and replace the oil pump, believe me it will get better for the engine.
RSR 555 wrote:If money is no worries, then definitely go with option C, as this will mean you don't have to pull it apart for a while.
TroyTroia
Post by TroyTroia » Sun Oct 20, 2013 10:05 pm
Definitely option C mate.. The extra coin will do you favors in the long run.. You won't regret it :)
