Could this be my fuel pump?
jims
Post by jims » Wed Aug 07, 2013 6:54 pm
Hey everyone,
Trouble with the l series and similar to what I have experienced before. Engine running fine when you are on the throttle but as soon as it drops back to idle it cuts out. Keep it above 1000rpm and it is okay but below that and it konks out. Carb has been rebuilt, Checked Pcv? valve, and idle solenoid. All seem okay. Could this be my fuel pump on the way out?
James
Post by steptoe » Thu Aug 08, 2013 9:04 am
You'd think anything but fuel pump - float setting in carby ? Can you see a little window ?ao
jims
Post by jims » Thu Aug 08, 2013 10:48 am
No window to float level on mine but was reset only four or five months ago. Will give the idle jet and carb a good spray with cleaner to see if I can 'flush' out the problem.
Post by El_Freddo » Thu Aug 08, 2013 10:16 pm
I'd say blocked idle jet - from my limited knowledge of carbies these days!
Have you run your tank low recently - you may have picked up some crap that's passed through the fuel filter and ended up in the carb blocking something to do with the idle mixture.
My thoughts anyway!
stork955
Post by stork955 » Fri Aug 09, 2013 7:25 am
G'day, check the idle cut solenoid. It should click when connecting and disconnecting it with the ignition on.
Stork
jims
Post by jims » Fri Aug 09, 2013 1:56 pm
Thanks guys,
Yep checked the idle cut solenoid.
You might be onto something there Bennie. Did run the tank low recently. Gave the idle jet a good spray with cleaner and the problem has gone away. Thanks for the advice!
Post by El_Freddo » Sat Aug 10, 2013 8:10 pm
jims wrote:Thanks guys,
No worries, that's what we're all here for!
Replace your fuel filters too ;)
