LSD L series
pzs
LSD L series
Post by pzs » Tue Jul 30, 2013 9:34 pm
Was there ever a LSD fitted to a L series as rear diff option ?
sublime
Post by sublime » Tue Jul 30, 2013 11:54 pm
Not as an option, no. The RX Turbo, however, had a LSD as standard.
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
Post by El_Freddo » Thu Aug 08, 2013 9:49 pm
sublime wrote:Not as an option, no. The RX Turbo, however, had a LSD as standard.
This rings true with me too. The 4wd Vortex XT would have an LSD as well.
Post by steptoe » Fri Aug 09, 2013 7:32 am
El_Freddo wrote:This rings true with me too. The 4wd Vortex XT would have an LSD as well.
Don't think so...
There were also two versions of the AWD Turbo Vortices too , one auto, one manual.
Thinking of L Series RX, was the LSD an option or the norm ? The auto version of the RX - the GLTA did not have fitted as standard anyway
sublime
Post by sublime » Fri Aug 09, 2013 9:42 pm
LSD was standard on the RX Turbo with the manual only. As you have noted steptoe, the automatic turbo did not have an LSD diff. I suppose Subaru felt the 'automatic' 4wd system would suffice for the auto. Ahhh... Remember the tag line? Subaru - from the land where tomorrow has already arrived!
No idea about the Vortex...
Old Boxer Tricks
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
Post by guyph_01 » Sat Aug 10, 2013 12:28 pm
yeah dont think the vortex had lsd, my old one didn't...
Post by TOONGA » Sat Aug 10, 2013 1:05 pm
Mine doesn't either ...
nor a front LSD :( ...
I do have the mythical diff lock though :)
Post by El_Freddo » Sat Aug 10, 2013 8:19 pm
TOONGA wrote:Mine doesn't either ...
Interesting. I always thought the AWD vortexes came with a rear LSD standard - every one I've seen at the parts yards that have been AWD always have the rear diff missing as well, hence why I thought it was an LSD. 3.7 ratio diffs are too common to grab one with the gearbox in my eyes...
FujiFan
Post by FujiFan » Sat Aug 10, 2013 9:45 pm
The ex JDM disc brake rear end that I got with the matching D/R AWD box for the wagon has the open wheeler 3.7:1 :(, yet it came with the 18mm stabiliser bar:D
Very rare find these LSD's!
I say one of us go on a world wide hunt and bring back a pallet load for all AUSubaru members;)
Post by steptoe » Sun Aug 11, 2013 7:59 am
There'd be one in the back of twilights RX for sale, maybe one in Discos too !
Post by TOONGA » Sun Aug 11, 2013 9:49 am
I do know when I use my diff lock I get extra bind front and back, but after researching a little it seems the vortex LSD was a factory option :(
this page while rather old is very interesting.
even the wikapedia XT article doesn't say anything about the vortex getting an LSD
I was looking at diffs from other vehicles at the wrecker the other day and with a bit of trickery and magic I think I know of one in the 3.7 range that could be shoehorned into a brumby. However it would need modified CV shafts and fabricated diff housing. Mind you it would open up a whole avenue of lockers and LSD centres for the diff :)
pzs
Post by pzs » Thu Aug 22, 2013 7:58 pm
What diff ratio are the rx lsd?
brumbyrunner
Post by brumbyrunner » Fri Aug 23, 2013 1:29 am
They were all 3.7:1 but you can change it to whatever you like
Settlement Creek Racing
pzs
Post by pzs » Fri Aug 23, 2013 7:23 pm
So If I'm running a ea82 engine, (not interested in engine swaps) with 14 inch rims a good all round ratio would be 3.9 to compensate and drive the underpowered ea82?
I have obtained a rx rear end with LSD and disc's....I am assuming its a LSD at the moment until I get to have a good look at it, it is missing sticker on the housing
Post by El_Freddo » Fri Aug 23, 2013 7:35 pm
pzs wrote:So If I'm running a ea82 engine, (not interested in engine swaps) with 14 inch rims a good all round ratio would be 3.9 to compensate and drive the underpowered ea82?
The rim size has nothing to do with gearing, the tyre diametre is what changes your gearing.
I've had a 14 inch rim with the stock 23 inch diametre tyre size, and I've got a 14 inch rim with 27 inch tyre diametre. So I guess it's more about the tyre size you want to be running.
But 3.9 would be better with larger tyres over the 3.7 diff ratio ;)
pzs wrote:I have obtained a rx rear end with LSD and disc's....I am assuming its a LSD at the moment until I get to have a good look at it, it is missing sticker on the housing
Lucky fella. I hope the rear diff is an LSD ;) I'll be jealous.
brumbyrunner
Post by brumbyrunner » Sat Aug 24, 2013 7:57 am
3.9 is better than 3.7 with std tyres. Are you swapping your gearbox to 3.9 also?
pzs
Post by pzs » Sat Aug 24, 2013 11:00 am
Yes I just assumed that both would need doing?
What diff's did the 3.9 come in?
Post by El_Freddo » Sat Aug 24, 2013 1:13 pm
Just grab the rear diff out of the same car you get the 3.9 ratio gearbox from. If you've only got the box they can be found in the l series, although harder to find these days, or the early liberty, again, some searching needed.
Get the gearbox first as these are harder to find than a rear diff of the required ratio IMO.
pzs
Post by pzs » Sat Aug 24, 2013 2:27 pm
Early liberty...thanks I'll have a look around town and see if I can grab some out of a wreck.
I assume after all the reading I have done, it would be a straight crown wheel swap in front and rear diffs?.
I would split my new LSD and my original gearbox as it only has 130000km on it.
Post by El_Freddo » Sat Aug 24, 2013 6:14 pm
pzs wrote:Early liberty...thanks I'll have a look around town and see if I can grab some out of a wreck.
I was under the impression we're talking about an L series here - correct?
I only ask as the L series gearbox can't have the pinion shaft swapped out like the EJ AWD gearboxes can. Unless you're going to use an EJ gearbox in the L series, if that is the subi you have that we're discussing...
