earth to starter
earth to starter
Hi all, just replaces both front bearings on my 92 brumby. Went to start and it would only click. Lifted the bonnet and noticed that the earth wire that is connected to the car under where the spare tyre lives isn't connected to anything. Does this go to the starter ???? Please help
- Bantum
Time to add one of these ...
Starter Relay ...
This should fix any issues that you have + make sure that you use the right gauge wire ...
Cheers, Bantum ...
Cheers, Bantum ...
G'day, not sure specifically about Brumbies, but there is two ways to earth the car properly.
1- The negative terminal has a large cable that goes from the battery to the block, and then a smaller one runs from the block to the body.
2 - The Large cable goes to the block as above, and a second smaller lead goes directly from the battery to the chassis. I think that is the standard Subaru way thinking about my L's.
Basically you must have a large wire to the block to handle the starter currents (200 amps or so), the smaller one carries the current for the lights, heater, etc, around 40 amps or so. Hope that makes sense and helps.
Stork
Stork
