Oil leak! EJ 25 twin cam.....
- Battlewagon
Got to work today and when I stopped, smoke started pouring out from under the bonnet!
Seems theres an oil leak somewhere on the front of my motor, appears to be drivers side...checked oil level...its down, but not dramatically so...
Topped up oil before heading home....smoke every time I stopped.
Got home, checked oil, down just a little...
Any suggestions as to what it may be? cam seals?
- Battlewagon
- Battlewagon
Frog can get you genuine ones.
Gannon's right FROG is good for parts.
There is another way to go about it - Drop into rockauto dot com, find your model that's the same as the US market, find your engine and the kit you need. Find in the list of kits the one you're happy with - I went with a Dayco kit as I know that brand name.
Take the kit number and search for it on fleabay motors US. I got my SOHC EJ cam belt kit minus water pump for just over half of what I could get it here including postage.
There is a risk involved with this way to save on coin though. It gives me a bit of a gambling feeling sometimes
- Battlewagon
Well, I went and bought the bits from my local parts place..and the timing belt is teflon lined.....I'm a little confused as to why?
So, I did a quick fix, installed the new seals to stop the leak and put the new idlers in....then a belt from a motor my mate rebuilt and ruined one week later.
It's ok, but I would like to fit the new belt....anyone had experience with them?
