wideband
On a narrowband sensor, any voltage between 0.1v and 0.5v indicates a lean mixture, between 0.5v and 0.9v is rich. There is no 'in-between' because its a narrowband sensor.
A wideband on the otherhand is quite linear and can indicate exact values, but cant be read without a dedicated controller.
So are you borrowing a wideband clipped onto your exhaust tip to test your factory o2 sensor?
So .... 0.5V is happy stoich ? I get the LEDs on my O2 reader from xxxxinstruments dance about giving various indications consistent with the tail pipe analyser, so not just a lean or rich read out, four bars either side of centre are used.
I got awful readings all over the shop when I shoved the wide band analysers sensor behind the turbo pre cat, yet nice and tidy at the tail pipe where it counts for pollution
Because of the non linear operation of the narrowband sensor, it only produces 0.5v at exactly stoich mixtures. Because of this its impossible for an ECU to hold mixtures at this point so its much more reliable to swing the mixture back and forth slightly and use the oxygen sensor to reference the centre of the swing. This is why you display flashes from lean to rich and back rapidly. As the sensor ages, the response time gets longer until its too slow for the ECU to make use of.
