Gas Stuts for tailgate L Series Touring Wagon
Mushroom
Post by Mushroom » Fri May 17, 2013 10:54 am
Hey Guys,
I want to replace the Gas struts for the touring wagon as it no longer holds the tailgate up (found that out the hard way Ouch!!). I found they are different to a normal wagon and the mobile strut guy couldnt do anything for me.
I called sun Spares and they had none either.
I called subaru and got the following part numbers:
RH side: 60107GA450
LH side: 60107GA460
But they said they are no long avalible, has anyone got any suggestions??
Troy
Post by Gannon » Fri May 17, 2013 11:45 am
Mushroom
Post by Mushroom » Fri May 17, 2013 11:47 am
No sorry mines a touring wagon they are a bit different :(
Post by Gannon » Fri May 17, 2013 12:01 pm
Mushroom
Post by Mushroom » Fri May 17, 2013 12:21 pm
yep thats the ones and just ordered them thanks heaps!!!
Post by steptoe » Fri May 17, 2013 4:05 pm
makes me feel better for throwing my last pair knowing the above :)
Post by El_Freddo » Wed May 22, 2013 10:32 pm
You can get them re-gassed as well, usually cheaper than new units!
I scored a set from a wreckers - they're that good that you get the rear door open to about 40ish degrees (window angle) and the struts do the rest from there! It will hit you in the head if you're not careful!
And I wouldn't have them any other way!
Mushroom
Post by Mushroom » Thu May 23, 2013 8:37 am
Well the arrived on Tuesday and fitted perfectly :)
To regas them was going to be $60 and no guarantee that the seals would hold or for $20 more I got the new ones delivered to my door
tambox
Post by tambox » Thu May 23, 2013 6:56 pm
There's a place in Dandenong called Mc Naughtons, they sell struts cheap and they can adjust the pressure in them while you wait. They have a range of sizes and different ends to suit many applications.
I've bought them for other uses, never needed one to suit a Subie yet, I've still got spares:)
L serious, still.
