Custom Bullbar?
ajames
Custom Bullbar?
Post by ajames » Wed Apr 24, 2013 10:37 pm
Has anyone done a custom bullbar for a L series? I had a look but can't find anything like what I'm trying for (i.e. more a replacement bumper than a 'round the headlights' effort) - Anyone got pics?.
Post by El_Freddo » Thu Apr 25, 2013 1:24 am
You mean you're after something like this or a nudge bar setup?
If you're after a nudge bar you can unbolt the side loops on mine. Others are a one piece. These can be had from ebay for $50. I wouldn't pay any more than that - but make sure you get the bits under the bumper that bring it all together, otherwise you won't be able to attach it to your bumper unless you've already got the framework there.
Post by RSR 555 » Thu Apr 25, 2013 2:34 am
He's one I brought off AndrewT a few years ago. I would have like the centre bar posts to be a bit wider but this was fine for the price. I got one made for my orginal L.Series Touring Wagon back in 1990 and it was around $700 back then.. god knows what they would cost today??
ajames
Post by ajames » Thu Apr 25, 2013 9:22 am
thanks guys, after finally finding a search term that worked, i found a few good ones, but if you know of any more of similar style i'd be more than happy to see whats around.
ajames
Post by ajames » Thu Apr 25, 2013 9:46 am
Another question, is 'thick wall' (not sure on exact thickness yet) 50mm galv cyclone fence pole ($15 per length) likely to be strong enough for bar work (front, rear and sliders)?
Post by El_Freddo » Fri Apr 26, 2013 12:49 am
Ah, you're after a custom tube bar...
IMO I wouldn't go overboard on thickness with the front bar, you want it to remain light yet still bend in an impact so that the body doesn't absorb the impact. Let the bar do that!
My bar in the pic above has had a wallaby strike at 110km/h on the left hand side, that bent right back without hitting the headlight, the wallaby went under the vehicle - hairy! I didn't have lift then either.
The bar was straightened out and the valance panelling the same as best as I could. Other than that all were ok.
Post by steptoe » Fri Apr 26, 2013 7:27 am
Someone had a bar that was essemtialy a replacement for the plastic bar, looked like that of the white wagon in pics above but no tubes, Mudrat ?
T.Farm.Brumby
Post by T.Farm.Brumby » Fri Apr 26, 2013 1:44 pm
I know it's on a Brumby but the principle's the same. Also not tube, but solid as.
http://www.subarubrat.com/bumper2.htm
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
Post by NachaLuva » Fri Apr 26, 2013 7:22 pm
ajames wrote: Image
This one looks awesome...gives the L a sense of real purpose! :twisted:
vincentvega
Post by vincentvega » Sat Apr 27, 2013 7:51 am
NachaLuva wrote:This one looks awesome...gives the L a sense of real purpose! :twisted:
Agreed. Thats the best looking L bar I have ever seen
Sent from my GT-N8010 using Tapatalk HD
ajames
Post by ajames » Sat Apr 27, 2013 3:15 pm
That's pretty much the front bar sorted, now I'm also interested in a similar rear bar and rock sliders... has anyone done that kind of bar work?
Post by El_Freddo » Tue Apr 30, 2013 2:02 am
ajames wrote:now I'm also interested in ... rock sliders... has anyone done that kind of bar work?
It's on my to do list :rolleyes: Mount points are the problem along with the usual lack of time :(
ajames
Post by ajames » Tue Apr 30, 2013 9:36 pm
Haha so true... I found a piece of pre-bent tube that I was going to cut up and use for a muffler replacement section then I lined it up at the back and thought to myself it could work well as a rear bar with a bit of work... time to get creative with the grinder!
v81200
Post by v81200 » Fri May 31, 2013 10:37 pm
my L bars
2012 PHONE PICTURES 041.jpg (34.03 KiB) Viewed 5038 times
2012 PHONE PICTURES 042.jpg (35.77 KiB) Viewed 5042 times
2012 PHONE PICTURES 045.jpg (28.35 KiB) Viewed 5044 times
