OBD II scanner for 2004 Outback
Need to pick up a low cost OBD II code reader ASAP. A while back tried an Autel MS509, which seemd to work intermittently, now looking at the AL519 off ebay for $120. Apparently item located in Melbourne. Anyone had any success with this unit?
Driving a MY04 Gen04 Outback. Apparently there were some issues with pre-2006 subbies and OBDII in Oz. Looked at a few of the code reader variants, need something stand-alone to chuck in the glove compartment and retrieve when necessary, rather than all the other possibilities. Any advice appreciated.
I personally haven't used this model but it looks like it should do the job.
Are you having troubles with your Outback?
Yep.. just got to remember when I'm at the workshop. I'll check today for you.dyrgutt wrote:BTW RSR_555: Did you get my msg re the cam wheel etc. Cheers
- TOONGA
According to the scantool website if you download the latest software it should work.dyrgutt wrote: what about the elmscan ones on eBay... does anyone know if these work on Subees?
