Brumby Bonnet - aftermarket
Anyone know where/if I can purchase aftermarket bonnet or skin for an 89 Brumby?
- Bantum
I don't know of any aftermarket bonnets, but you can get an 'applied skin' of carbon if that's what your after ?
I would'nt bother with it though, as it's hard to apply & doesn't realy suit the Brumby ...
Another option is this :
carbon fiber vinyl
carbon fiber vinyl
No one ever made an aftermarket bonnet for the MY series, so you had to go genuine. I'd be betting that Subaru now don't have any stock left, so best to find someone wrecking one.
- Bantum
Appliqué ...
Na - The real stuff ( see my first line in post above ) as it's messy, not easy to apply & takes ages to do properly ...
The problem with vinyl on bonnet is that it only has a short life span of 4 to 5 years, ( check the guarantee if you don't believe me ) can be attacked by scratching & heat affects bonding, where the adhesive tends to bubble up too !
Window tinting is usually Ok, as it's generally applied on the inside of glass, but it still wears & is also affected by the weather ...
In short - much trouble for very little gain ...
Well we could give you another answer but you wont like that one eitherWooster wrote:Cheers guys, I therefore take it the real answer is NO!
cool
