bad camber
- king_kawaka
bad camber
Hi all i need some help sorting out camber issues. i have a 88 l series wagon 4wd.i have just replaced the front struts / shocks and now have a major camber issue.the struts and springs are of standard height. now my wheels sit like this \ /. i have driven about 300km hoping they will settle but still major camber and are scrubbing my tyres like you would not belive. i have also picked up a clunk in the front after changing them what is goin on all info will be greatly appreciated
Have you got left and right struts on their wrong sides?
- king_kawaka
bad camber
i did 1 side at a time and the car is stock as a rock (no lift kit yet) the ride hight changed about 1/2inch which is expected with new shocks i installed brand new gabriel shocks / struts with adjustable ride height. ride height is wound all the way down ( lowest posistion )
Did you do the strut change at one go or one wheel a time? The hats could be in wrong position as it needs to be lined up.
- king_kawaka
They're called Strut Hats. Yes they do need to be installed in correct way/lined up. There is often a single hole or a slot marker on the top that needs to line up to the bottom of the strut.king_kawaka wrote:struts were done one at a time so sides can not be mixed up thats what has me stumped . can the mounting plate with the 3 blots on top of the strut be installed wrong? are there any markings on these to check if installed correctly?
- king_kawaka
- king_kawaka
- king_kawaka
ok i found the marks on the strut top hat there are 2 dimples in the rubber part which line up with the 2 holes drilled in the top of the strut tower. i also replaced the balljoints but still have a slight clunk sound when going up a 45deg gutter. i am now also noticing a chatter sound when doing 90 - 95 kms/hr with a light tug on the steering wheel at 100k + the chatter seems to disapeer or less than 90k/hr it is not there any suggestions to what the issue might be all help and pointers will be greatly appreciated thank you
