JDM 4 pots on Outback
Davidov
Post by Davidov » Wed Jan 16, 2013 2:59 pm
Hi,
I will be putting some JDM 4 pots on my Outback and they are a simple bolt on affair, however I am unsure about whether I need to replace the brake master cylinder/ brake booster with the matching JDM gear?
I have the gear however will it affect my hill holder and pedal feel by changing it? I like the feel it has currently and the hill holder, so if i can keep them I would like to.
Post by AlpineRaven » Wed Jan 16, 2013 3:50 pm
It will fit but depending on your rim clearance
Davidov
Post by Davidov » Wed Jan 16, 2013 5:00 pm
AlpineRaven wrote:It will fit but depending on your rim clearance
Already have new rims to fit lined up. :)
Post by El_Freddo » Wed Jan 16, 2013 10:13 pm
Depending on what the calipers came from you might have to change the disc rotor to suit too.
Do a search about it - Venom when this way with his liberty - larger rims and rotors...
Davidov
Post by Davidov » Wed Jan 16, 2013 10:51 pm
El_Freddo wrote:Depending on what the calipers came from you might have to change the disc rotor to suit too.
My Gen 3 OB Rotors are the same dimensions as the rotors the 4 pots came off (I have these also). If i need to i can use the others, my OB ones are just in better condition (JDM rotors only have 100k kms but are covered in surface rust from lack of use and being imported etc).
Im just unsure about the brake booster/ master cylinder.
Post by Gannon » Thu Jan 17, 2013 5:05 am
Booster/cylinder will be fine.
