Bit of a late Xmas pressie for myself
Post by Silverbullet » Fri Dec 28, 2012 1:11 pm
I've been wanting one for ages, spent alot of time researching which one to get and which model will do what I want. I wasn't going to buy any cheap rubbish from Bunnings so splashed some major dosh today and bought this :D
It'll do all 3 welding processes up to a maximum of 175 amps (minimum 10) Has an inverter power supply so can plug into a 15A 240V socket and came with a whole load of goodies including a decent MIG torch, Stick electrode holder, a gas line and gas regulator/flow meter as well as feed rollers from .6 to 1.2mm wire. All in a decent carry bag :rolleyes: Also bought a 5kg spool of solid .8mm wire for all my panel steel.
Now all I need is to source a bottle of argoshield and I'll be ready to start busting some rust on the old wagon :twisted:
taza
Post by taza » Fri Dec 28, 2012 1:14 pm
Nice! Do you mind if I ask how much it cost?
Post by Silverbullet » Fri Dec 28, 2012 1:17 pm
Everywhere that has them sells this same kit for exactly $1k.
Post by El_Freddo » Fri Dec 28, 2012 4:27 pm
Silverbullet wrote:Now all I need is to source a bottle of argoshield and I'll be ready to start busting some rust on the old wagon :twisted:
And that's the costly bit! You even pay rent on the bottle per year :(
You'll love the MIG, once you've got it setup right to do what you want you'll be cooking! If you need to change to another job that requires a different setup write down the settings for your last job! Painful when you forget what you had it setup for on a particular job!
Post by Bantum » Fri Dec 28, 2012 4:36 pm
Nice one ... :)
Yeah, shop around to find somewhere that sells the disposable type bottle ( no rent )
Cheers, Bantum ...
Post by Silverbullet » Fri Dec 28, 2012 5:18 pm
Yes, gas is the costly part. I wasn't too keen on the small disposable bottles since I don't want to run out of gas halfway through a job. Looked around a bit and there aren't many places that do proper bottle rentals...so I have to go with BOC who have just upped their prices apparently :(
For a D2 sized bottle (knee height) is $90 something for the gas and $14/month rental. I'll go by the month because a whole years rental in advance costs too much, and this way I can stop renting it when I'm not using it.
Post by El_Freddo » Fri Dec 28, 2012 5:53 pm
Silverbullet wrote:Yes, gas is the costly part. I wasn't too keen on the small disposable bottles since I don't want to run out of gas halfway through a job. Looked around a bit and there aren't many places that do proper bottle rentals...so I have to go with BOC who have just upped their prices apparently :(
I think you'll find that those other places are renting from BOC - they have the market cornered since they're really the only providers of gas products AFAIK
Silverbullet wrote:For a D2 sized bottle (knee height) is $90 something for the gas and $14/month rental. I'll go by the month because a whole years rental in advance costs too much, and this way I can stop renting it when I'm not using it.
You'll loose out with the remaining gas in the bottle when you return it. I will guarantee that they won't hold the bottle for you for when you want it next - you'll have to get a new bottle every time.
Post by steptoe » Fri Dec 28, 2012 7:37 pm
air liquide is another supplier but charges were greater through them than the Bunch of c crowd last year 'bout this time
Post by Silverbullet » Fri Dec 28, 2012 10:59 pm
Never mind, I may have found a way to get the gas a bit cheaper. Can't believe I was gonna get charged $90 for a D sized bottle of gas, when someone I know gets the full sized bottle for $50! :shock: What's going on here. They really do have the market cornered :(
