swap a tranny?
swap a tranny?
Hi,
Doing some work on the wagon during my time off, and I plan on changing my transmission. Currently got a 3AT in it which works fine, but I much prefer manuals, and I would like to take advantage of a dual range setup. So here comes my question.
Looks like Im going to pick up a 80's sedan with D/R 4wd with a stuffed motor for next to nothing. As my wagon is an MY, with the ea81 and the sedan is an L-series with an EA82, am I going to be able to use the clutch, pressure plate and throw out bearing with the EA81 or do I need some gear from an 81 tranny? Done a fair bit of reading on USMB and here so I roughly know what else is in store but was mainly conserned Id need to hunt down other parts from another car.
My other thoughts were along the lines of buying a wrecking brumby and stealing its D/R 4 spd, which should all bolt straight up. I mainly drive in the city so overdrive isnt really a big selling point for me.
Can anyone shed some light on the whole clutch/pressure plate/flywheel question for me?
Doug
Doug
- Bantum
What video ?
Um ... Great news, but the video is crap. You can't see nothin on it as it's all washed out ...
Correction ... Only if I play it on here, if you go to the youtube site it plays ok there ...
Looking good Doug.
Was the car originally gold in colour?
Possible a short at the brake pedal switch?
Do you have a spare one off the auto pedal box?
You must have crimped a wire when putting the column back in. Just drop it down a touch and riggle the wiring around a bit
Pretty sure Black with white trace is Ignition feed +ve
Yeah it is, from what the fuse box says that fuse is for both the stop lights and the room lights. Id say that black and white wire was supplying power to the lights in the car roof. Too bad, they didnt work all that well anyway. This car has the most messy, crappy, add this, add that, wiring I have ever seen. Everytime I have to do something under there its a headache.
Good news is I just took the car for a blat with the new tranny. Everything works as expected. Gates feel good and it still goes into reverse
. now just to finish up the 4wd selector and its ready for some bush.
Doug
Doug
Yeah, great to hear the car is driving again
The auto speedo cable is longer and people change to the auto when they fit a lift kit in, as the mechanical stays in place but the body is lifted up.
