Where is the Brumby chassis number
Anybody know where the chassis number is stamped on a Brumby ?
- FROG
has to be on part of the main body construction
ie firewall is ok but on a door etc is not!
Like everyone has mentioned, it's on the body because it's a monocoque design, it needs to be stamped to the main body section. It is also stamped into the compliance plates and must be matching for rego.
LX Torana does not a monocoque body
The reason you don't need plates is when these were driven off the Ark, they didn't have polution regs to "comply" with
RSR 555 wrote:LX Torana does not a monocoque body
Oh.. so the front rails are NOT removable from the main body?niterida wrote:Yes it is
Sorry, I was under the impression that a 'monocoque' (meaning one shell) meant that there was only one frame to the vehicle and not multible parts???
RSR 555 wrote:The reason you don't need plates is when these were driven off the Ark, they didn't have polution regs to "comply" with
Did what? Drive off the Arkniterida wrote:Yes they did
Only polution stuff on my SS Hatchback was a hose from the oil cap to the air cleaner housing.
Nah the frame is not removeable - your thinking of the HQ.RSR 555 wrote:Oh.. so the front rails are NOT removable from the main body?
Theres more than that - sealed carby screws so you can't adjust the idle etc etc. Yours probably had most of it removed anyway.RSR 555 wrote:Did what? Drive off the Ark:p:p hahaha
And the only car around when Noah was driving would have been a Mk 1 Brumby hahahahahahahaha
You could be right there.. I know there has been many bottles of bourbon since I had my SS.niterida wrote:Nah the frame is not removeable - your thinking of the HQ.
More than likely.. it wasn't very stockniterida wrote:Theres more than that - sealed carby screws so you can't adjust the idle etc etc. Yours probably had most of it removed anyway.
I do believe the Torana is older than the Gen1 Brumbyniterida wrote:And the only car around when Noah was driving would have been a Mk 1 Brumby hahahahahahahaha
Ok.. we'll ask the good people of AUSubaru...niterida wrote:Maybe but which one looks younger ??
Where's your pic of your torrie??
Never heard of this beforeniterida wrote:you don't even need any tags to get it registered as long as the chassis number has been rego'd before.
#$@# me!! What's the plan with this one - you going to repair all of that? Nasty stuff rust, I hate the stuff - HATE IT!niterida wrote:
Yeah the LC/LJ toranas are monoque as well, no removable chassis from front to rear. I would have classified the HQ as the same due to the body having the front end mounted on the body without chassis rails under the car, I'm sure these things are the same as the HK's in that department, if not I'm crossing over from the HK/T/G's that do this.
Maybe I should look up it's meaning...
Yeah its going to be fixed up - rust is easy fixed - just takes time and patience and a lot of welding wire..............
Hatchbacks are hard to find in any condition and are worth a fortune. A guy on the torana forum just sold a bare repaired shell (just a base SL) in primer for $15,000 !!
Plan is to either run completely standard Torana with a fuel injected 304 or just use the body and put Toyota Supra/LS400/Celsior 1UZ V8 and complete running gear under it. Leaning towards the toyota
- Brumby Kid
1uz!!!
Hydrochloric acid is great for rust!
