Brake Fluid Light
555Ron
Brake Fluid Light
Post by 555Ron » Sun Dec 02, 2012 5:31 pm
My 1991 Brumby has started to have an intermittent issue with the brake fluid light. It comes on usually after being parked and it will eventually turn itself off - seems to be after going up a hill. I've taken the cap off and the float seems to free. Does anyone know how the switch mechanism works on this - if it is repairable? I have recently had the dash out but I don't think it is the loom or the dash. Or does anyone have a spare cap with the wiring loom?
Ohh, and the fluid level is full.
Post by TOONGA » Sun Dec 02, 2012 7:01 pm
The light not only lets you know that the fluid is low it tells you if there is a leak in the system. My vortex has a leaky front left caliper ( it comes and goes normally in winter) and when it leaks and loses pressure the light comes on.
