blown head gasket!!!
__BIG__RICH__
Post by __BIG__RICH__ » Sun Dec 02, 2012 5:16 pm
hey all, its been a long time since i posted here...
so ive got a 1999 subaru impreza rx, and yesterday it overheated into the red, this is the first problem ive ever had with my car, i was able to get the car home but were unsure exactly wat damage has been done.
my mechanic is coming tomorrow to have a look and see what exactly is wrong.. i think its either the thermostat or head gasket... im not looking forward to paying that money to fix it.. but it has to be done...
does anyone know a workshop around south brisbane side that can fix it for a good price??
thanks in advance :)
Post by El_Freddo » Mon Dec 03, 2012 1:02 pm
A couple of things to check first, one that should be done regularly - how was your coolant level prior to the over heating episode?
You can check the oil for water/coolant contamination easily. A compression check can tell you if one or neighbouring cylinders is down, clear sign of a head gasket with the over heating experience.
Check your fuses to make sure the fan relay fuse isn't blown - your AC won't work if it is.
Just because you've been in the red doesn't always mean you've done a HG. And what's the condition/age of the water pump and radiator. Could be worth getting a flush done on the system. Also check your rad hoses and fittings. The lib I'm currently driving was purchased by a mate (I'm his team mechanic :P) with a suspected blown HG. First start when warming up we found a pin hole in the top rad hose, thus we found where all the coolant was going. That was two years ago now :D
All the best with it, I'm hoping its something simple!
Post by AlpineRaven » Tue Dec 04, 2012 6:20 am
And another thing have you checked if you have any bubbles in the system sometimes it can send wrong signal - happened to me a few times thinking i cooked the engine but turns out to be air in the system.
