I am doing some research into a 2” lift on my 97 SF Forester and have a few queries.
I think i will be going with:
KYB struts: Excel G twin tube gas shock [F- 3341 89/90 R- 3341 91/92]
King Springs (Aus): HD 30mm Rise [F- KSFR-32 R- KSRR-33 (req KBY 334191/2 struts on rear)] $250-350
Or
Dobinson Springs (Aus): HD 35mm Rise [C55-045] Similar price to Kings
One of these:
Subtle Solutions (USA): 1” lift kits $200-250
Velocity Offroad (USA): 1.25” Alloy spacers
Jackson Rally (USA): 1” tophat spacers
Does anyone know of any 1” tophat spacer suppliers in Aus?
Eibach or white line camber bolts
All new bushes and ball joints.
Will look into options for the sway bar arrangment.
Bash plate
Interested in bullbar, rear bar and snorkel also
So here is the bit where i need some help:
What is the difference between the stock struts and these KYB struts?
Do the KBY struts provide any lift or only when combined with springs/tophat spacer?
What is stiffer, Kings or Dobinsons?
For those of you that have already lifted you cars in a similar way to this; what was you final gain in hight after everything had settled in? I want to get as close to 50mm as i can and need to work out the best combination of springs/spacers.
Has anyone tried using spacers between the sway bar and chassis to help maintain its normal alignment with the rest of the suspention?
Where in Western Australia can i get all this gear?
Also happy to hear any other sugestions to achieve the 2"
Aus law only allows an increase in tyre diameter of 15mm so im gonna stick with my 205/70/15 tyres for now.
In the future i may look into a body lift and larger wheels but it will require an engineering certificate to be legel and maintain insurence.
I am compileing a list of all the manufacurers of these components that i shall post soon.
Thanks in advance for you help
Cheers Daniel
