Hard to select reverse in my Brumby
- Brumbyowner
Hi guys,
I hope you can help, I am finding it hard to get into reverse. I took it to a Subi man, he replaced a bolt in the selector sleeve and it worked for a short time. It has returned and he said that the problem is the sleeve or rod is worn and it is expensive to repair. Is this right and am I up for an expensive repair?
showthread.php?t=18699&highlight=sloppy+shifter
Post #1 is the diagram of the shifter mechanism, Post #4 is the parts you'll need. Just assuming it's too sloppy to get it into reverse?
- TOONGA
http://www.indysworld.com/80s/general/U ... erFix.html
gives you all the details you need to fix the problem
I have cut a two groves with an angle grinder in the sleve so when the bolt is tightened the sleve becomes a clamp onto the shaft.
- Brumbyowner
Steptoe,
Nup.... the gear lever is rather sloppy and it is just as hard to get in with the engine stopped or running. I took the Brumby into Pedders so they could do a complete suspension check (theres another $1900!!) and they guy couldn't get it into reverse. I had to wrestle the bugger to get it in for him.
- d_generate
Tried putting in second gear first? Works on my 4.44 box on the odd occasion it doesn't want to play.
I'd be telling pedders where to go at that price!
Surely you could replace every bush, spring and strut/shock for half that price and a bit of effort!
They'll probably be adding their suspension parts which will greatly change the handling characteristics of the vehicle. I've heard many people ask "pedders?" when talking suspension on a particular vehicle, their usual reply when my answer is yes is something like "yeah, thought as much!"
- Brumbyowner
- Brumbyowner
- Brumbyowner
