final drive ratio change?
- jakebrumby
how hard is it to change the final drive ratio on a brumby? would like to go to 27 inch tires but its gutless enough already... any suggestions?
- thunder039
Depends on the diff ratio you have now, there are two available to suit the Brumby, either 3.7 or the lower 3.9.
Check, see what you have, 3.7 is more common.
Otherwise $$$$$$$$$$$$$$$$$$$$$$$$$$$ to get a custom 4.1 or 4.4 diff ratio box made, probably in an L series box to give you the best of everything, then fitting it.
Yep two sets of wheels is much easier
- jakebrumby
- phillatdarwin
- jakebrumby
I'd be looking for a 2L foz gearbox - 1.447:1 low range, 4.11 ratio diffs from the factory. But to fit this box you'd need to modify the gearbox crossmember, drop in an EJ or re-house the gearbox in an L series casing (it slots straight in and bolts up to the EA81) and then organise a new tail shaft as well as a custom gearstick levers/setup using either the L series or EJ setup, I'm not sure which one works best or what exactly needs to be done as I've not done it before.jakebrumby wrote:know where i can get one?
But that gearbox re-casing trick does work - I've got an L series gearbox in EJ casings for my EJ conversion. Venom has an L AWD gearbox in EJ casings as well. It can go the other way too. Thinking about it the late model gearboxes might have a larger bearing on the input shaft, but this can be sorted with a new bearing that fits the outer and inner diametres as required.
