BRZ Transplant Options ...
Post by Bantum » Wed Aug 29, 2012 5:55 pm
As I had another look at the pic's I'd taken of this example : BRZ 070
A thought came into my head ... :idea: ... Wouldn't this be an ideal transplant package for the Brumby ? ... :p
( Package meaning: Engine, Gear Box, Drive Line, Brakes, Suspension, Wiring + possibly dash )
Hmm, I think more info' is needed on this one though ... :confused: ... Any one else had the same notions ?
Also we would have to wait 'till they start turning up in the wreckers yard, etc ...
So it's just a thought for now ... :(
P.S. - What other Subaru 'models' do you think this package can go into ?
thunder039
Post by thunder039 » Wed Aug 29, 2012 6:04 pm
a few years time maybe.... that is of course the brumbys arent rusted out by that stage ;)
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by Gannon » Wed Aug 29, 2012 6:25 pm
And no doubt that the ECU will be incorporated into every other electrical in the car, most likely sprouting a BCM and running CANBUS, an auto electricians nightmare.
If I were to go to that much trouble, Id get one of the diesels from a new Forester or Outback and whack that in the Brumby
Post by El_Freddo » Wed Aug 29, 2012 6:37 pm
Gannon wrote:no doubt that the ECU will be incorporated into every other electrical in the car, most likely sprouting a BCM and running CANBUS, an auto electricians nightmare.
I hate that shit! Such a waste in the "recycling" community such as ourselves!
I think you're getting "a little" ahead of yourself there Bantum! Personally, if it could be done I'd go for a H6 brumby, that'd be off it's tits! Otherwise it'd be what Gannon's said above or the tried and tested WRX drivetrain swap ;)
discopotato03
Post by discopotato03 » Thu Aug 30, 2012 7:50 am
If you were really keen you could run it off a good aftermarket computer and if it only has to meet a Brumbys era emissions standards a good tuner should be able to get it to pass . Need similar to OE exhaust and cat/s though .
BRZs are not going to be cheap or easy because they are current cars .
Single cam per bank EJ20 much easier .
A .
Post by steptoe » Thu Aug 30, 2012 8:36 am
sadly, the emissions of the donor engine are supposed to remain with it in retrofits. I reckon things might be better if someone came up with a reinforced tub kit with trace paper to apply to a Forester, cut along the lines, bolt here, there and everywghere and hey presto! a Forester ute ! No welding just modern glue assembly methods, rivets and bolts :) .
More Options ...
Post by Bantum » Thu Aug 30, 2012 1:06 pm
thunder039 wrote:... that is of course the brumbys arent rusted out by that stage ;)
Or spare parts start getting harder to find ... :neutral:
Gannon wrote: ... And no doubt that the ECU will be incorporated into every other electrical in the car, most likely sprouting a BCM and running CANBUS, an auto electricians nightmare...
Unfortunate, but that's the way every thing is heading nowadays ... :(
Gannon wrote:... If I were to go to that much trouble, Id get one of the diesels from a new Forester or Outback and whack that in the Brumby...
Yea, I had thought of that too ... Although I'm waiting untill some other bunny has done the job first so that I can learn from their experience.
El_Freddo wrote: ... I think you're getting "a little" ahead of yourself there Bantum! Personally, if it could be done I'd go for a H6 brumby, that'd be off it's tits! Otherwise it'd be what Gannon's said above or the tried and tested WRX drivetrain swap ...
I did say at the outset that this was only an Idea ... :rolleyes: ... Had also thought of the H6, however it would require a lot re-enginering to make it fit in the Brumby, as it is a much bigger beast ( From my understanding it take's up radiator & floor space with a bigger gear box, etc ) but it has been done before in a MY wagon I think... :cool:
discopotato03 wrote: ... If it only has to meet a Brumbys era emissions standards ...
steptoe wrote:... sadly, the emissions of the donor engine are supposed to remain with it in retrofits ...
These two contradict each other, which is it ? ... :confused:
steptoe wrote:... I reckon things might be better if someone came up with a reinforced tub kit with trace paper to apply to a Forester, cut along the lines, bolt here, there and everywghere and hey presto! a Forester ute ! No welding just modern glue assembly methods, rivets and bolts ...
Hah, I like the idea - but not sure if it would work in practice ... :p
Post by Alex » Thu Aug 30, 2012 1:22 pm
quit dreaming!
niterida
Post by niterida » Thu Aug 30, 2012 2:01 pm
Bantum wrote: These two contradict each other, which is it ? ... :confused:
Both !!
You must meet the emissions regulations for the body and the engine.
So if you put a 2012 engine in a 1980's car then it must meet the 2012 regs.
If you put a 1980's engine in a 2012 car then it must still meet the 2012 regs.
In other words it must meet the regulations of whichever one is newer.
Clearer now ...
Post by Bantum » Fri Aug 31, 2012 3:24 pm
niterida wrote: ... it must meet the regulations of whichever one is newer ...
Ahh ... That's what I thought too, thank's niterida ... :D
Another Query ...
Post by Bantum » Sun Jan 27, 2013 1:53 am
When I was looking over the beast, I noticed that the intake manifold appears to be made of some sort of plastic, can anybody confirm this ?
I also checked out the underside ...
Interesting ... :)
Post by Gannon » Sun Jan 27, 2013 6:52 am
Yeah the intake manifold is made from a fibre reinforced resin, a little better than plastic and Subaru have been using it for 10 years now. It first appeared in the 2003 EZ30 of the Gen4 Liberty/Outback
Undertray would be for reduced wind drag
dfoyl
Post by dfoyl » Sun Jan 27, 2013 7:39 am
BRZ engine into an rwd / awd EA81 coupe sounds good to me... 147kW in a body 300 kg lighter than a BRZ.
Post by TOONGA » Sun Jan 27, 2013 10:40 am
Remember this from the USA? EJ motor to toyota transmission
I'm sure it would cost way less in the long run and everything is already available to make a subi RWD. you could even use this bellhousing in conjuction with a toyota transfer case to make a very low, low range.
Dreamers ...
Post by Bantum » Sun Jan 27, 2013 2:13 pm
Alex wrote:... quit dreaming! ...
Ha, Never ! - I was re-reading posts on here & that one snuck through ... :)
Where would the world be with out the dreamers ? ( 'The Castle' comes to mind here )
More Options ...
Post by Bantum » Sun Jan 27, 2013 2:34 pm
Gannon wrote:... Yeah the intake manifold is made from a fibre reinforced resin, a little better than plastic and Subaru have been using it for 10 years now. It first appeared in the 2003 EZ30 of the Gen4 Liberty/Outback ...
Interesting, I wonder how well they hold up over time to temp, UV etc - It appears to be a trend for more composite materails ... :neutral:
Gannon wrote:... Undertray would be for reduced wind drag ...
No shit Sherlock, I was more commenting on the scaloped sides ... :roll:
dfoyl wrote: ... BRZ engine into an rwd / awd EA81 coupe sounds good to me... 147kW in a body 300 kg lighter than a BRZ ...
This is all a possiblity, but it would still require some engineering to achieve ... :-D
TOONGA wrote: ... Remember this from the USA? EJ motor to toyota transmission ...
No, but I went & had a look, interesting work he's got going there, I'm not sure I'd want to go that far at this time ... :p
TOONGA wrote: ... I'm sure it would cost way less in the long run and everything is already available to make a subi RWD. you could even use this bellhousing in conjuction with a toyota transfer case to make a very low, low range ...
Yeah each to their own, non committal to this & as I stated prevoiusly, we're only dreaming here ... :p
Post by TOONGA » Sun Jan 27, 2013 3:22 pm
Bit of a hangover there Bantum?
Post by 60766244 » Sun Jan 27, 2013 10:26 pm
Sounds' like it would be easier to modify the BRZ into a modern Brumby ;) - I'd buy one!
Start:
Chop:
Add:
More Sub Mods ...
Post by Bantum » Mon Jan 28, 2013 1:40 am
TOONGA wrote: ... Bit of a hangover there Bantum ? ...
Ha - Sadly no I'm sorry to say, but I did get sidetracked by this ... :D
More here : Merkuru ... Note : Spoiler Alert - This is a long thread ... ;)
Just spent the last few hours reading this epic build & wow, not sure I'd want to do it - but I like it ... :)
BRZ Ute ...
Post by Bantum » Mon Jan 28, 2013 2:12 am
60766244 wrote: Image
Yeah - I sort of like your idea, but it does need a bit more thought in how to deal with rear end & B pillar does'nt quite look right ... :wink:
There might bee a wee problem with the lights & width of opening ... :(
Also goes for depth of floor :
With a strange half step for spare ...
P.S. - Here are some more underside shots of the BRZ :
Up front there's not much to see :
Nice rear end setup :
Might be that a bit of experimention is required to see if the rear tray & shell of Brumby body could be grafted somehow to the BRZ ?
It would look a bit odd though ...
Cheers, Bantum ... :p
