Brumby Project
Wesvo
Brumby Project
Post by Wesvo » Mon Aug 27, 2012 8:42 pm
I am wondering what I should do, my engine. Needs a recondition, don't know how much and can't find a manaul transmission that can take a turbo, like a ea82t manaul transmission to keep the high and low 4x4 gears! need help assap like a new or recondition motor ie ea81 and the transmission and shaft etc what ever is need to fit the different transmission ie!
Post by El_Freddo » Mon Aug 27, 2012 10:32 pm
Welcome to the forum.
Wesvo wrote:I am wondering what I should do, my engine. Needs a recondition, don't know how much and can't find a manaul transmission that can take a turbo, like a ea82t manaul transmission to keep the high and low 4x4 gears! need help assap like a new or recondition motor ie ea81 and the transmission and shaft etc what ever is need to fit the different transmission ie!
Do a search on WRX conversion - only if you're good at spinning spanners and troubleshooting. If not forget it and just get a replacement engine or yours rebuilt.
Wesvo
Post by Wesvo » Tue Aug 28, 2012 7:02 am
El_Freddo wrote:Welcome to the forum.
Thanks bennie
I kinda looked at conversion to much $$$ dosh! Looking for rebuilt engine and ea82t gear box high and low!
Post by steptoe » Tue Aug 28, 2012 7:47 am
Bennie ! What are you doing, trying to corrupt a fellow Vic member ? Or has VicRoads gone lenient on power ups like WRX in Brumby ?
I am running a standard L Series 5 speed box 4WD dual range behind a 10 or 12 :) psi EA82T - 50,000km so far ..... touch wood
Post by TOONGA » Tue Aug 28, 2012 10:06 am
Take a look at my brumby build, the first post has all the details.
Im currently getting 500 km to 50 ltrs which should improve when I rebuild the carby.
(or when I drive like a grandpa)
the biggest issue is the making of the manifold for the carby, if you can find a EJ18 SPFI manifold you will only need to modify it a small amount to fit a carby to it.
Post by El_Freddo » Wed Aug 29, 2012 9:48 pm
steptoe wrote:Bennie ! What are you doing, trying to corrupt a fellow Vic member ? Or has VicRoads gone lenient on power ups like WRX in Brumby ?
As far as I know you can still engineer them with the upgraded ***** conversion kit. It's just $$$ and another hoop to jump through :(
steptoe wrote:I am running a standard L Series 5 speed box 4WD dual range behind a 10 or 12 :) psi EA82T - 50,000km so far ..... touch wood
I too am running a standard trim L series 5 speed in EJ casings (essentially the L series gearbox) and have thus far done about 70k km with an EJ22 in front of it. Killed a clutch in that time but other than that everything's been good.
