97 outback cel issue
outtheback97
Post by outtheback97 » Fri Aug 10, 2012 4:44 pm
hi there long time user first time poster. I recently bought a 97 outback limited (200k on odometer). It has, since i've owned it come up with an intermittent CEL. I used this forum and others to figure out it was poo032. Quote from subaru was large so i ordered 02 sensor from repco for $120 ish. Today I replaced the sensor, cleared codes, went for a drive and it still threw out the poo 32 code. Took my car to local subaru dealership who were really good ( didnt charge me). They plugged in there diagnostic and we stuffed around for a while. They came to the conclusion that its a dud sensor. Went back to repco who will get me another one for free, nice.
The car had a replacement motor just prior to me purchasing it. The suby tech noted it is a newer ej25 and still uses the original extractors. My question is, is there any chance i need a different (ie newer) o2 sensor to match the slightly newer engine? I recently did oil/filter and plugs/leads and the car runs better (less miss at idle and a bit smoother) but my fuel economy is poor.
ps I went to the joint who replaced the motor and they wanted 110 to just plug in and clear. :rolleyes:
I've got plans for this beast (lift, bullbar, sump guard) but just need to get the motor sorted. Thanks in advance
outtheback97
Post by outtheback97 » Mon Aug 13, 2012 6:23 pm
So I got the replacement replacement sensor in, cleared codes and it still comes up. (032) So the sensor wasnt a dud. I read a thread on here about testing with a multimeter at the ecu. If I do this test and it isnt getting the volt change it should what will i need to do? Money is tight and i dont like the idea of going to an auto elec if i can help it.
Post by El_Freddo » Mon Aug 13, 2012 6:46 pm
Is there only one o2 sensor in the system? I know some of the later subaru units have two o2 sensors in the exhaust system, dunno if yours is one of these though - it's beyond my experience.
As for your question about the engine - so long as the wiring matches the sensors on the engine you should be all good in that department.
FROG
Post by FROG » Mon Aug 13, 2012 6:54 pm
need to know if ecu was swopped in with the engine or not - can you find out?
outtheback97
Post by outtheback97 » Mon Aug 13, 2012 6:58 pm
There is only one 02 sensor on my car. That could be it, the newer motor may have come from a car with the rear sensor as well.
I can find out, i'll call them tomorrow. Cheers
FROG
Post by FROG » Mon Aug 13, 2012 7:10 pm
Aussie spec? Jap spec?
find out what you can - vin from donar car would be nice :-)
