l series 4wd doesnt work
will123
Post by will123 » Sun Jul 22, 2012 9:50 pm
Recently bought an 85 l series wagon and can't figure out if the 4wd is working or not. When I press the button on top of the gear stick, nothing happens. Thought at least a light on the dash would come on or is their none? I took it off-road and got bogged pretty quickly and that's when I found out only the front wheels were turning.
Someone please help! The only reason I bought it was too go offroading
Brumby Kid
Post by Brumby Kid » Sun Jul 22, 2012 10:15 pm
Hey,
Welcome!
Don't think I can help here too much but...
Im guessing it's an auto?
Where this button connects to... Check for wires.
If you can trace them you might find something.
As this would be an electrical 4wd select as apposed to a mechanical 4wd select.
Please, pics and details of your l series.
I would assume we can expect mods?
Btw where is ottoway? I should know but don't.
Cheers Cam
Dads Car: 02 Impreza WRX STi
will123
Post by will123 » Sun Jul 22, 2012 11:00 pm
Thanks for reply
Not auto, manual with a 4wd button on top of the gearstick
Will have a Suss at the wiring tomorrow, hopefully its as simple as a disconnected plug/wire.
Ottoway is down Port Adelaide area
thunder039
Post by thunder039 » Mon Jul 23, 2012 10:24 am
i haven't heard of the l series having the 4x4 select button on the gear shifter
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by TOONGA » Mon Jul 23, 2012 11:09 am
The switch on the gearstick is for the vacuum actuator solenoid that selects the 4WD option in the later models of the L series. (or is it for the touring wagon?) "L" series enthusiasts to confirm please :)
I would be checking the vacuum lines on your motor as well as the ones going to the gearbox.
if you don't have a service manual as a guide they can be found here
Post by RSR 555 » Mon Jul 23, 2012 1:32 pm
Yep, sounds like it's not engaging 4WD :( I would check to see if the solenoid (the one for the vacuum module on the sid of the g/box) is working when you press the button. If you have a spare person, turn the ignition on (so the dash lights up) and then put your ear near the solenoid valve (from memory it's up on the LHF strut tower) and get your friend to continuously press the button in and out.
If not noise from valve, then check for power with a multimeter.
If you get noises then check the vacuum lines are not cracked or disconnected.
There should be 4WD lights appear on the dash when it's engaged.
will123
Post by will123 » Mon Jul 23, 2012 8:45 pm
Thanks so much
Turns out it was an unplugged vacuum hose. Such a simple fix was doing my head in, thanks again.
Now time for a lift kit and some chunky rubber :-)
thunder039
Post by thunder039 » Mon Jul 23, 2012 8:52 pm
will123 wrote: Now time for a lift kit and some chunky rubber :-)
thats what we like to hear
Post by El_Freddo » Tue Jul 24, 2012 7:29 pm
will123 wrote:Now time for a lift kit and some chunky rubber :-)
And a dual range gearbox ;) It'll bolt straight in, you will need the dual range gear selector setup as well plus the console to match/make it look pretty.
If you ever do this let me know, I'll be keen to purchase the push button gear selector from you if you ever part with it!
Enjoy! I can see another L series mod thread coming on :twisted:
Welcome to the forum!
Post by RSR 555 » Wed Jul 25, 2012 12:33 am
[quote="El_Freddo"]If you ever do this let me know, I'll be keen to purchase the push button gear selector from you if you ever part with it!/QUOTE]
I'm thinking you are going to do the same as me ;)
I have a blue one if you like?
Post by El_Freddo » Wed Jul 25, 2012 12:37 am
RSR 555 wrote:
El_Freddo wrote:If you ever do this let me know, I'll be keen to purchase the push button gear selector from you if you ever part with it!
Yeah I am and yeah I would. I'll PM later when talking other things with you - saves on inbox space ;)
