Post 3 photos of your workplace.
Post by Gannon » Wed Jun 27, 2012 2:07 pm
I just thought it would be interesting. Doesnt matter where you work, just snap 3 photos and upload them
I have been roughing in the electrical wires in a largeish house
Edited with my folding computer thingy
Post by steptoe » Wed Jun 27, 2012 2:39 pm
Be even more interesting if the pictures came through! And when you master it, I may have to crank up my HuRwe sitting idle with no sim card :(
niterida
Post by niterida » Wed Jun 27, 2012 3:13 pm
I could but then I would lose my job........................
Post by Alex » Wed Jun 27, 2012 5:26 pm
i cant really show photos, but i can give you a link so you can see what im doing at the moment.
http://www.pta.wa.gov.au/perthcitylink/
im a structural designer responsible for the tunnel works.
taza
Post by taza » Wed Jun 27, 2012 5:38 pm
Can't post pics either as I work at client companies doing IT work. Currently onsite now at a university... In Perth.
I can post pics of my old work when i get home.
Post by Silverbullet » Wed Jun 27, 2012 6:08 pm
Well I might get some strange looks from everyone if I went round the press shop taking photos, but there are 210 ton presses in there dating back to 1956 that are 2 storeys high with a 2M diameter flywheel constantly spinning at a few hundred rpm, along with the newer 300 ton machines that are even bigger! Big enough they have their own ladder and balcony :o
Only photo I have is of a pile of blocks I had to grind up. It's a tooling and manufacturing company that makes all their own tools and my job at the moment is to use a surface grinder to make all the blocks perfectly square and +/- .005mm in dimensions before they go to be CNC machined into forms, dies, crop blades, punches etc. They use many different kinds of tool steel ranging from not much harder than mild steel to the hardest I've encountered so far, K110 which gets hot after a .02mm cut on the grinder :sad: takes ages to grind that stuff since you have to wait for it to cool down every time (the only grinder with coolant is currently too innacurate to use) These 7 particular blocks are M238 and about 150mm x 70 x 50, all had to be absolutely identical.
niterida
Post by niterida » Wed Jun 27, 2012 7:04 pm
Silverbullet wrote:my job at the moment is to use a surface grinder to make all the blocks perfectly square and +/- .005mm in dimensions
hmmmmmmmm
Post by Silverbullet » Wed Jun 27, 2012 7:36 pm
Hey it was a few weeks ago and I can't remember every block I grind :p I usually get a pile of blocks and a list of the item numbers and their dimensions, the actual dimensions are just arbitrary numbers but I still get them within 5 microns of those arbitrary numbers :eek:
Post by Gannon » Thu Jun 28, 2012 5:47 am
steptoe wrote:Be even more interesting if the pictures came through!
Mmmm thats embarrassing. First time of trying to upload with my phone
Post by steptoe » Thu Jun 28, 2012 8:42 am
Did th resulting pics work through your iphone or backup method ? Some untidy buggers around leaving shtuff around for the sparky to crack his ankl on !! The builder needs to put a bit of fear in some of the workers esp if he has a skip provided. Is that the ocean in the background ? aa-aaaagh ....... relaxing eh ?
purp
Post by purp » Thu Jun 28, 2012 11:54 am
I work in an office at the moment, which isn't terrible exciting. But here are some very serious pics...
Fun size mars and snickers, wrapped in puff pastry and baked....
Post by steptoe » Thu Jun 28, 2012 12:26 pm
Are you Sirius ?
purp
Post by purp » Thu Jun 28, 2012 1:44 pm
steptoe wrote:Are you Sirius ?
I was, but now I'm in the building next door.
Richie-Rich
Post by Richie-Rich » Thu Jun 28, 2012 6:05 pm
Best job in the world.
purp
Post by purp » Thu Jun 28, 2012 6:59 pm
Richie-Rich wrote:Best job in the world.
I don't want to alarm you, but your propeller blades are terribly bent. :rolleyes:
Post by steptoe » Thu Jun 28, 2012 10:49 pm
Are you sirius -the Mars bar inside puff pastry !? get any goop onya tie ? :)
Post by steptoe » Thu Jun 28, 2012 10:57 pm
Thought I'd bend yer rules a little ...here is a pic of my first workplace ....20,12
Was a Bee Pee Station , now a community swimming hole
Next place was a kitchen joinery - now a mechanical workshop
Place #3 was an Esso servo & mechanical workshop , now a clubhouse and community pool , er select community that is :)
Uploaded with ImageShack.us
olddog642
Post by olddog642 » Thu Jun 28, 2012 11:37 pm
[quote="purp"]I work in an office at the moment, which isn't terrible exciting. But here are some very serious pics...
Hey Doc. looks like Canberra Hospital to me
:evil::twisted:
1111giles
Post by 1111giles » Fri Jun 29, 2012 6:28 am
Silverbullet wrote:Well I might get some strange looks from everyone if I went round the press shop taking photos, but there are 210 ton presses in there dating back to 1956 that are 2 storeys high with a 2M diameter flywheel constantly spinning at a few hundred rpm, along with the newer 300 ton machines that are even bigger! Big enough they have their own ladder and balcony :o
Hey - do you need a shiney new Wire EDM or Sink EDM to help your tool room do its stuff ? :D if so check out what I sell as part of my job.
Clicky the linky http://www.sodick.org or this one for our UK direct site http://www.sodi-techedm.co.uk & you might even be able to find a piccy of me in there ! :p:;)
Giles.
1111giles
Post by 1111giles » Fri Jun 29, 2012 6:37 am
purp wrote:I work in an office at the moment, which isn't terrible exciting. But here are some very serious pics...
Thats my Kinda Office !:D
Giles.
