What should I be doing for 100K Outback Service?
Hi all,
I'm looking to do the 100K service on my 2004 3 litre Outback. I've ordered the NGK platinum plugs from the USA ($97 for 6 delivered, as opposed to $24 each locally!) and I'll obviously also do the oil and oil filter, but what else should I be doing?
Fuel filter? Air Filter? Transmission fluid? Power Steering fluid? All of the above, none of the above? What else?
Thanks in advance for your help.
Yeah get in contact with forum member 'FROG' who sells genuine Subaru parts. He'll get you all the filters needed for your service.
Yes you should flush the radiator, but I wouldnt worry about the power steering.
Yes.
You should be doing engine oil, transmission fluid, diff oil, brake fluid, coolant, oil filter, transmission filter, air filter, fuel filter, spark plugs. Anything that's replaceable basically gets done at 100k.
100k and 200k are the major service intervals for the car apart from the normal minor services in between
Sent from my HTC Velocity 4G using Tapatalk 2
